R: [Qgis-user] ecw files
Evert Groenewald groenewalde at frogfoot.net
Mon Jun 9 10:30:14 PDT 2008
David Fawcett het geskryf:
> Hmmmm....
> Are there any work arounds, like a downloadable pluggin?
> It looks like gvSIG may support .ecw.  I will have a look there too.
> I need to quickly find a solution for some field staff.
> Thanks,
> David.
> On Mon, Jun 9, 2008 at 10:59 AM,  <marco.pasetti at alice.it> wrote:
>> ECW support is not available in qgis (and also GRASS) for Windows native.
>> There's a problem with its license (of ECW) about binary redistribution,
>> that is not clearly permitted nor compatible with both GRASS qnd QGIS
>> licenses.
>> Marco
>> ________________________________
>> Da: qgis-user-bounces at lists.osgeo.org per conto di David Fawcett
>> Inviato: lun 09/06/2008 17.55
>> A: qgis-user
>> Oggetto: [Qgis-user] ecw files
>> I am running QGIS 0.10.0 on Windows and trying to get a large .ecw
>> file to load.  Based on the documentation, it appears as though QGIS
>> should support .ecw files.
>> When I try to load the file, I get a warning dialog that says that the
>> file 'is not a supported raster data source'.  gdalinfo is able to
>> open it up using the 'ECW/ERMapper Compressed Wavelets' driver.
>> Granted, this is a giant image (~27gb), but if it was a size issue, I
>> would expect a crash instead of the warning.   Maybe I am just used to
>> the expensive, proprietary stuff ; /
>> Thanks,
>> David.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
I think you should try FWTools as it can open .ecw files.
evert
