[Qgis-user] ecw files
Tim Sutton
tim at linfiniti.com
Mon Jun 9 14:39:35 PDT 2008
Hi
Is the gdal info you are using to test using the same gdal libs as in
the qgis install directory? I'm not sure if Marco built the windows
version with .ecw support - traditionally we havent shipped ecw
support due to licensing issues. If you have a gdal library on your
system that includes ecw support, you could experimentally try
dropping its dlls etc into the qgis folder. I would suggest making a
backup first since you may break everything if the gdal you have was
built using a different compiler to QGIS.
Hope that helps
Regards
Tim
2008/6/9 David Fawcett <david.fawcett at gmail.com>:
> I am running QGIS 0.10.0 on Windows and trying to get a large .ecw
> file to load. Based on the documentation, it appears as though QGIS
> should support .ecw files.
> When I try to load the file, I get a warning dialog that says that the
> file 'is not a supported raster data source'. gdalinfo is able to
> open it up using the 'ECW/ERMapper Compressed Wavelets' driver.
> Granted, this is a giant image (~27gb), but if it was a size issue, I
> would expect a crash instead of the warning. Maybe I am just used to
> the expensive, proprietary stuff ; /
> Thanks,
> David.
> Qgis-user mailing list
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
