[Qgis-user] Re: Problem with gdal_vrtmerfe
Agustin Lobo Agustin.Lobo at ija.csic.es
Tue Jun 10 04:40:26 PDT 2008
True, it works fine now, thanks again.
These vrt files seem a great way for dealing with long
time series of images.
Agus
Maciej Sieczka wrote:
> Agustin Lobo pisze:
>> I run:
>> alobo at alobo-laptop:~/CHINA$ ./gdal_vrtmerge.py -separate -o tm2.vrt *.tif
>> and get:
>> ./gdal_vrtmerge.py: line 1: !DOCTYPE: No such file or directory
>> ./gdal_vrtmerge.py: line 2: PUBLIC: command not found
>> ./gdal_vrtmerge.py: line 3: syntax error near unexpected token `newline'
>> ./gdal_vrtmerge.py: line 3: `
>> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">'
>> I'm using ubuntu hardy, have gdal and FWTools 2.0.6
>> (i.e. gdal_merge.py works fine)
>> Is there anything I have to do in order to install gdal_vrtmerge.py ?
> You have downloaded the file wrong.
> Propably you went to [1], right-clicked the [2], "saved as", tried to
> run the file. This won't work because what you got is an XHTML file. You
> have to download it raw: go to [1], *left-click* [2], navigate to
> bottom, left click "Original Format".
> [1]http://trac.osgeo.org/gdal/ticket/1985
> [2]http://trac.osgeo.org/gdal/attachment/ticket/1985/gdal_vrtmerge.py
> Maciek
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
