[Qgis-user] ArcGis mdb file
John C. Tull
john.tull at wildnevada.org
Sat Jun 14 15:05:34 PDT 2008
Although I am pretty certain that format requires Windows as an Access
lib is used by gdal. So no joy on Linux or OS X without a virtual
machine.
Regards,
John
On Jun 14, 2008, at 5:29 AM, Jeff McKenna wrote:
> GDAL does have read support for mdb files (http://gdal.org/ogr/drv_pgeo.html)....so
> you should be able to use GDAL's ogr2ogr utility to convert your
> mdb into a readable format for QGIS.
> --jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 14-Jun-08, at 7:37 AM, Nikos Alexandris wrote:
>> On Sat, 2008-06-14 at 13:19 +0200, Agustin Lobo wrote:
>>> How? I do have MDB tools, but don't see how
>>> I can open the arcgis mdb file (which has geographic information)
>>> with QGIS.
>>> I can open the tables with MDBTools, but cannot
>>> open the mdb file as I do with a shp file in QGIS.
>>> Agus
>>> Ralf Suhr wrote:
>>>> In general yes, but the geometry-column has a format, that I
>>>> don't know to
>>>> convert.
>>>> For mbd-access http://mdbtools.sourceforge.net/
>>>> Ralf Suhr
>>>> Am Samstag 14 Juni 2008 schrieb Agustin Lobo:
>>>>> Can arc gis mdb files be opened with qgis
>>>>> under linux (ubuntu)?
>>>>> Thanks
>>>>> Agus
>> I am also interested in this. Till now I just open an .mdb file with
>> gmdb2 0.6pre1 (a gnome mdb viever) and export as .csv
>>> From this point it is easy to import in openoffice.Calc or import in
>> GRASS' data base and then play around with it (in GRASS or QGIS).
>> Greets,
>> Nikos
> Qgis-user mailing list
