[Qgis-user] Can't view non public schemas
Simo D
simone.dalmasso at gmail.com
Wed Jun 18 05:11:03 PDT 2008
Yes, thank you it's solved.
There was an issue in postgis extension.
Thanks Ralf
Simone
Ralf Suhr wrote:
> Hi Simone,
> have the non public schema the postgis extensions?
> are the schemas included in the variable: search_path?
> are the geometry-columns writen to the geometry_columns Table (public
> schema)?
> For a new schema I use a template build from a public schema. The template
> include all the postgis extensions, what is needed for a qgis query.
> Ralf Suhr
> Am Dienstag 17 Juni 2008 schrieb Simo D:
>> Hi all. I'm trying to connect to a postgis database with a public and
>> some
>> non public schemas. The schemas have all grant permissions but with qgis
>> I
>> can see only the public schema. Whit my psql client I can see all and the
>> connection parameters are the same.
>> Can anyone help me?
>> Thanks a lot.
>> Simone
> Qgis-user mailing list
View this message in context: http://www.nabble.com/Can%27t-view-non-public-schemas-tp17881244p17981380.html
Sent from the qgis-user mailing list archive at Nabble.com.
