[Qgis-user] creating a .prj file for a shapefile that doesn't have one
Carson Farmer
cfarmer at uvic.ca
Wed Jun 18 08:25:32 PDT 2008
Regie,
You can define the projection (create .prj files) of vector layers using my srsmanagement plugin. This plugin also allows you to project layers to different projections afterwards as well.
It is available here:
http://www.geog.uvic.ca/spar/carson/
or if you have QGIS > 0.9.2 you can add:
http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
to your python plugins repository in your plugin installer and install it
directly from there.
There are instruction at the address above as well...
Cheers,
Carson
Regie Alam wrote:
> Hello,
> Is there a way to create an associated .prj file
> for a shapefile that doesn't have one?
> I tried searching the forums archive but couldn't
> find a topic related to this.
> Thanks,
> Regie
> Qgis-user mailing list
