[Qgis-user] creating a .prj file for a shapefile that doesn't have one
Regie Alam
alamred at yahoo.com
Thu Jun 19 05:04:02 PDT 2008
Hello Carson and Carlos,
Thanks very much for the info. Took some time to
get it going since I didn't realize right away that
the instructions was meant for 0.9.2 or higher (I
missed this below). Once I had it setup everything
worked as expected.
I also found out in order to access the Plugin
Installer it has to be installed first from the Plugin
Manager.
---- Carson Farmer <cfarmer at uvic.ca> wrote:
> Regie,
> You can define the projection (create .prj files) of
> vector layers using my srsmanagement plugin. This
> plugin also allows you to project layers to
> different projections afterwards as well.
> It is available here:
> http://www.geog.uvic.ca/spar/carson/
> or if you have QGIS > 0.9.2 you can add:
http://www.geog.uvic.ca/spar/carson/cfarmerQgisRepo.xml
> to your python plugins repository in your plugin
> installer and install it
> directly from there.
> There are instruction at the address above as
> well...
> Cheers,
> Carson
> Regie Alam wrote:
> > Hello,
> > Is there a way to create an associated .prj
> file
> > for a shapefile that doesn't have one?
> > I tried searching the forums archive but
> couldn't
> > find a topic related to this.
> > Thanks,
> > Regie
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
