[Qgis-user] Reqgis 0.10 slow digitizing with grass
maning sambale
emmanuel.sambale at gmail.com
Thu Jun 19 19:32:04 PDT 2008
> I recommend exporting the "GRASS rgb images" (they are "groups", are
> they?)
rgb image from r.composite, using "groups" to display rasters slows
the render even more.
from GRASS into GeoTIFF with r.out.gdal.sh (if you go for the C
> r.out.gdal counterpart, make sure you run gdal_translate on the output
> to reduce the file size; somehow the C r.out.gdal produces GeoTIFFs
> bigger than gdal_translate can).
Thanks for pointing this out. (note to self: always run
gdal_translate when exporting gtiffs)
>Build overviews for your GeoTIFFs with
> gdaladdo then (I'd go external overviews - make the GeoTIFF read only
> and then run the gdaladdo on it to achieve this). Overviews should speed
> up their render times much.
Right, thanks! But, can QGIS build external overviews from native
GRASS rasters?
>> a shapefile.
> I'm not sure, but maybe building an index in QGIS can help, ?. And it
> would not harm to process the shapefile with ogr2ogr without parameters
> which might reduce it's size - I happened to notice this works with some
> Shapefiles I got. At worst, even if the shapefile won't render faster it
> will occupy less disk space and might have lower memory footprint.
I'm not editing the shapefile, but creating the index helps a bit.
I think the lag time occurs when editing, saving, re-rendering the GRASS vector.
I removed the raster's for now and it does improve rendering.
cheers,
maning
> Maciek
> Maciej Sieczka
> www.sieczka.org
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
