[Qgis-user] Reqgis 0.10 slow digitizing with grass
Maciej Sieczka
tutey at o2.pl
Thu Jun 19 23:53:46 PDT 2008
maning sambale pisze:
> Maciek wrote:
>> maning wrote:
>> I recommend exporting the "GRASS rgb images" (they are "groups",
>> are they?)
> rgb image from r.composite, using "groups" to display rasters slows
> the render even more.
>> from GRASS into GeoTIFF with r.out.gdal.sh (if you go for the C
>> r.out.gdal counterpart, make sure you run gdal_translate on the
>> output to reduce the file size; somehow the C r.out.gdal produces
>> GeoTIFFs bigger than gdal_translate can).
> Thanks for pointing this out. (note to self: always run
> gdal_translate when exporting gtiffs)
... but only when you export with the *C* version of r.out.gdal. The
*Shell script* one, r.out.gdal.sh, is itself a wrapper around
gdal_translate actually.
>> Build overviews for your GeoTIFFs with gdaladdo then (I'd go
>> external overviews - make the GeoTIFF read only and then run the
>> gdaladdo on it to achieve this). Overviews should speed up their
>> render times much.
> Right, thanks! But, can QGIS build external overviews from native
> GRASS rasters?
QGIS canot build external overviews at all. Which is a pitty as external
ovrs are more convenient. You need to use the gdaladdo GDAL CLI tool.
>>> a shapefile.
>> I'm not sure, but maybe building an index in QGIS can help, ?. And
>> it would not harm to process the shapefile with ogr2ogr without
>> parameters which might reduce it's size - I happened to notice this
>> works with some Shapefiles I got. At worst, even if the shapefile
>> won't render faster it will occupy less disk space and might have
>> lower memory footprint.
> I'm not editing the shapefile, but creating the index helps a bit.
> I think the lag time occurs when editing, saving, re-rendering the
> GRASS vector.
Do you have "Fix problems with incorectly filled polygons" checked? It
might boost vector rendering, depending on your system, as it enables
hardware acceleration for vector rendering.
Maciek
Maciej Sieczka
www.sieczka.org
