[Qgis-user] Still problems at building from svn
Agustin Lobo
aloboaleu at gmail.com
Fri Jun 20 01:56:22 PDT 2008
I'm trying to build from svn using ubuntu hardy (32 bits):
When I get to:
alobo at alobo-laptop:~/dev/cpp/qgis/build$ sudo apt-get install grass
libgrass-dev libgdal-1.4.0-grass
the system says:
Reading package lists... Done
Building dependency tree
Reading state information... Done
grass is already the newest version.
Package libgrass-dev is a virtual package provided by:
grass-dev 6.3.0-0
You should explicitly select one to install.
E: Package libgrass-dev has no installation candidate
how can I select?
I have:ls /usr/lib/libgdal*
/usr/lib/libgdal1.4.0.so.1 /usr/lib/libgdal1.5.0.a
/usr/lib/libgdal1.5.0.so /usr/lib/libgdal1.5.0.so.1.12.1
/usr/lib/libgdal1.4.0.so.1.11.4 /usr/lib/libgdal1.5.0.la
The web page states
"You may need to explicitly state your grass version e.g.
libgdal1-1.3.2-grass "
but do not quite understand that advice
I think this the reason why I get:
alobo at alobo-laptop:~/dev/cpp/qgis/build$ make
[ 0%] Generating qgssvnversion.h
[ 0%] Built target svnversion
[ 7%] Built target ui
make[2]: *** No rule to make target `/usr/lib/libgdal1.4.0.so', needed
by `src/core/libqgis_core.so.0.11'. Stop.
make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
make: *** [all] Error 2
Any help would be appreciated!
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
