[Qgis-user] calculate statistics on an attribute table
Alessandro Sarretta
alessandro.sarretta at inwind.it
Sun May 4 13:35:18 PDT 2008
With the spqr (http://www.maths.lancs.ac.uk/~rowlings/Software/Spqr/)
python-R plugin you can calculate some simple statistics.
Ale
Maciej Sieczka ha scritto:
> Mars Sjoden pisze:
>> Is there a way to quickly calculate statistics on an attribute table
>> column?
> Not that I know of. A workaround for doing this with external software:
> 1. open attrubute table in QGIS
> 2. select all rows (select first one, go to bottom of the table, press
> ctrl selecting the last row)
> 3. ctrl+c
> 4. open some spreadsheat/statistics software
> 5. paste
> If your layer is PostGIS you can use PostgreSQL advanced stats
> features directly. If you want to put your SHP into PgSQL use the QGIS
> SPIT plugin or shp2pgsql CLI utility.
> Best,
> Maciek
> P.S.
> Please don't hi-jack threads.
> Qgis-user mailing list
