[Qgis-user] Problem with proxy in 0.10.0
Christian Goutrie
goutrie at fh-brandenburg.de
Mon May 5 09:05:21 PDT 2008
Hello all,
I have a strange problem with the newest release and our proxy server.
I try to get new WMS layers from
http://mapserver.jrc.it/wmsconnector/com.esri.wms.Esrimap/image2000_pan
For security reasons we have to use a proxy server, but the latest release
only brings following error message:
"Could not understand the response. The wms provider said:"
Terminal gives an additional error:
Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
Server: squid/2.6.STABLE6
Date: Mon, 05 May 2008 15:58:06 GMT
Content-Type: text/html
Content-Length: 1047
Expires: Mon, 05 May 2008 15:58:06 GMT
X-Squid-Error: ERR_ACCESS_DENIED 0
X-Cache: MISS from proxy
X-Cache-Lookup: NONE from proxy:3128
Via: 1.0 srv
Proxy-Connection: close
Settings for proxy are:
URL: http://mapserver.jrc.it/wmsconnector/com.esri.wms.Esrimap/image2000_pan
Proxy Host: proxy
Proxy Port: 3128
Same settings did work in 0.8 and 0.9.
I can also exlude a problem with the remote server, as others also do not
work. If I omit the proxy and connect directly, it also works fine.
Any ideas?
Thanks
christian
