[Qgis-user] Problem with proxy in 0.10.0
Christian Goutrie
goutrie at fh-brandenburg.de
Fri May 9 10:15:23 PDT 2008
On Monday 05 May 2008, Christian Goutrie wrote:
> Hello all,
> I have a strange problem with the newest release and our proxy server.
> I try to get new WMS layers from
> http://mapserver.jrc.it/wmsconnector/com.esri.wms.Esrimap/image2000_pan
> For security reasons we have to use a proxy server, but the latest
> release only brings following error message:
> "Could not understand the response. The wms provider said:"
> Terminal gives an additional error:
> Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
> Server: squid/2.6.STABLE6
> Date: Mon, 05 May 2008 15:58:06 GMT
> Content-Type: text/html
> Content-Length: 1047
> Expires: Mon, 05 May 2008 15:58:06 GMT
> X-Squid-Error: ERR_ACCESS_DENIED 0
> X-Cache: MISS from proxy
> X-Cache-Lookup: NONE from proxy:3128
> Via: 1.0 srv
> Proxy-Connection: close
> Settings for proxy are:
> URL:
> Proxy Host: proxy
> Proxy Port: 3128
> Same settings did work in 0.8 and 0.9.
> I can also exlude a problem with the remote server, as others also do not
> work. If I omit the proxy and connect directly, it also works fine.
Ok, the problem is, that the 0.10. release does a CONNECT to reach the
server. THIS IS NASTY BEHAVIOUR, as this should be reserved to SSL proxy
connections and malware. Therefore many admins excludes CONNECT to other
ports than SSL enabled ones and that was the reason why it failed.
I didn't found a reason, why this was changed and no option to change this.
christian
The Unix Guru's View of Sex:
# unzip ; strip ; touch ; finger ; mount ; fsck ; more ; yes ; umount ;
sleep
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080509/d442b7a9/attachment.sig>
