[Qgis-user] Re: [Qgis-developer] rendering GRASS rasters broken in UTF-8 locale
Maciej Sieczka
tutey at o2.pl
Fri May 9 00:17:42 PDT 2008
Maciej Sieczka pisze:
> I'm currently using QGIS 0.10.0 + SVN r8401 on Debian tetsing x86, QT
> 4.4.0 rc1 in pl_PL.utf8 locale.
> Any GRASS raster (even as small as 50x50 cells) which has a
> colortable, freezes QGIS. QGIS last debug words, before pressing OK
> in the "Add GRASS raster" dialog, are attached in a txt file.
> Also, when I load a GRASS raster *without* a colortable it renders OK
> (ie. all-grey, as one would expect since it has no coloratable
> assigned), but when I try reducing the window size QGIS crashes,
> saying:
> Warning 1: GRASS fatal error: region for current mapset is invalid
> line 16: <e-w resol3: 29.98442368> run "g.region"
> When I start QGIS in C locale (eg. from a terminal after "export
> LC_ALL=C") neither of these problems take place - GRASS rasters with
> colortable are rendered OK and I can stretch/reduce the window as I
> like without a crash. What's wrong?
Folks,
Does anybody else have this problem too? Maybe it is just me.
Maciek
