[Qgis-user] Re: [Qgis-developer] rendering GRASS rasters broken in UTF-8 locale
maning sambale
emmanuel.sambale at gmail.com
Fri May 9 01:16:05 PDT 2008
I'm just doing the same in windows (QGIS Io)
GRASS DEM with colortables from r.colors color=etopo2
I get no problems so far
cheers,
maning
On Fri, May 9, 2008 at 3:17 PM, Maciej Sieczka <tutey at o2.pl> wrote:
> Maciej Sieczka pisze:
>> I'm currently using QGIS 0.10.0 + SVN r8401 on Debian tetsing x86, QT
>> 4.4.0 rc1 in pl_PL.utf8 locale.
>> Any GRASS raster (even as small as 50x50 cells) which has a colortable,
>> freezes QGIS. QGIS last debug words, before pressing OK in the "Add GRASS
>> raster" dialog, are attached in a txt file.
>> Also, when I load a GRASS raster *without* a colortable it renders OK
>> (ie. all-grey, as one would expect since it has no coloratable assigned),
>> but when I try reducing the window size QGIS crashes, saying:
>> Warning 1: GRASS fatal error: region for current mapset is invalid line
>> 16: <e-w resol3: 29.98442368> run "g.region"
>> When I start QGIS in C locale (eg. from a terminal after "export
>> LC_ALL=C") neither of these problems take place - GRASS rasters with
>> colortable are rendered OK and I can stretch/reduce the window as I like
>> without a crash. What's wrong?
> Folks,
> Does anybody else have this problem too? Maybe it is just me.
> Maciek
> Qgis-user mailing list
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
