[Qgis-user] manageR: Couldn't load plugin
Agustin Lobo
aloboaleu at gmail.com
Mon May 12 00:53:53 PDT 2008
Hi!
I have a problem with loading plugin manageR.
I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
I get
the following message at starting qgis 0.10:
Couldn't load plugin "manageR" from
['/home/alobo/.qgis//python/plugins', '/usr/local/share/qgis/python',
'/usr/local/share/qgis/python/plugins', '/usr/lib/python25.zip',
'/usr/lib/python2.5', '/usr/lib/python2.5/plat-linux2',
'/usr/lib/python2.5/lib-tk', '/usr/lib/python2.5/lib-dynload',
'/usr/local/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages',
'/usr/lib/python2.5/site-packages/Numeric',
'/usr/lib/python2.5/site-packages/PIL',
'/usr/lib/python2.5/site-packages/gst-0.10',
'/var/lib/python-support/python2.5',
'/usr/lib/python2.5/site-packages/gtk-2.0',
'/var/lib/python-support/python2.5/gtk-2.0']
File "", line 2, in
File "/home/alobo/.qgis//python/plugins/manageR/__init__.py", line 35, in
from manageR import manageRPlugin
File "/home/alobo/.qgis//python/plugins/manageR/manageR.py", line 40, in
import domanageR
File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line
39, in
from rpy import *
File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
""" % RVERSION)
RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so: undefined
symbol: KillAllDevices
RPy module can not be imported. Please check if your rpy
installation supports R 2.7.0. If you have multiple R versions
installed, you may need to set RHOME before importing rpy. For
example:
>>> from rpy_options import set_options
>>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>> from rpy import *
Is there anything I had to do and did not? Is there anything to set up
within R?
Thanks!
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
