[Qgis-user] manageR: Couldn't load plugin
Sebastien Vial
sebastien.vial at gmail.com
Mon May 12 01:00:12 PDT 2008
Hi !
Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
Does your RPY works with R 2.7 ?
Seb
2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
> Hi!
> I have a problem with loading plugin manageR.
> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
> I get
> the following message at starting qgis 0.10:
> Couldn't load plugin "manageR" from ['/home/alobo/.qgis//python/plugins',
> '/usr/local/share/qgis/python', '/usr/local/share/qgis/python/plugins',
> '/usr/lib/python25.zip', '/usr/lib/python2.5',
> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
> '/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages',
> '/usr/lib/python2.5/site-packages/Numeric',
> '/usr/lib/python2.5/site-packages/PIL',
> '/usr/lib/python2.5/site-packages/gst-0.10',
> '/var/lib/python-support/python2.5',
> '/usr/lib/python2.5/site-packages/gtk-2.0',
> '/var/lib/python-support/python2.5/gtk-2.0']
> Traceback (most recent call last):
> File "", line 2, in
> File "/home/alobo/.qgis//python/plugins/manageR/__init__.py", line 35, in
> from manageR import manageRPlugin
> File "/home/alobo/.qgis//python/plugins/manageR/manageR.py", line 40, in
> import domanageR
> File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line 39, in
> from rpy import *
> File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
> """ % RVERSION)
> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so: undefined
> symbol: KillAllDevices
> RPy module can not be imported. Please check if your rpy
> installation supports R 2.7.0. If you have multiple R versions
> installed, you may need to set RHOME before importing rpy. For
> example:
> >>> from rpy_options import set_options
> >>> set_options(RHOME='c:/progra~1/r/rw2011/')
> >>> from rpy import *
> Is there anything I had to do and did not? Is there anything to set up
> within R?
> Thanks!
> Agus
> Dr. Agustin Lobo
> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> LLuis Sole Sabaris s/n
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
> email: Agustin.Lobo at ija.csic.es
> http://www.ija.csic.es/gt/obster
> Qgis-user mailing list
Sébastien VIAL
Prof d'Info - Resp. TIC/Comm - Formateur SIG
Lycée Agricole du Balcon des Ardennes
http://www.lebalcon.fr
tel : 03-24-57-66-71
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080512/1c960814/attachment.html>
