[Qgis-user] manageR: Couldn't load plugin
Agustin Lobo
Agustin.Lobo at ija.csic.es
Mon May 12 02:14:37 PDT 2008
No idea, I installed rpy for using manageR. How can I test it?
Agus
Sebastien Vial wrote:
> Hi !
> Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
> Does your RPY works with R 2.7 ?
> Seb
> 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>> Hi!
>> I have a problem with loading plugin manageR.
>> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>> I get
>> the following message at starting qgis 0.10:
>> Couldn't load plugin "manageR" from ['/home/alobo/.qgis//python/plugins',
>> '/usr/local/share/qgis/python', '/usr/local/share/qgis/python/plugins',
>> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>> '/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
>> '/usr/lib/python2.5/site-packages',
>> '/usr/lib/python2.5/site-packages/Numeric',
>> '/usr/lib/python2.5/site-packages/PIL',
>> '/usr/lib/python2.5/site-packages/gst-0.10',
>> '/var/lib/python-support/python2.5',
>> '/usr/lib/python2.5/site-packages/gtk-2.0',
>> '/var/lib/python-support/python2.5/gtk-2.0']
>> Traceback (most recent call last):
>> File "", line 2, in
>> File "/home/alobo/.qgis//python/plugins/manageR/__init__.py", line 35, in
>> from manageR import manageRPlugin
>> File "/home/alobo/.qgis//python/plugins/manageR/manageR.py", line 40, in
>> import domanageR
>> File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line 39, in
>> from rpy import *
>> File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>> """ % RVERSION)
>> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so: undefined
>> symbol: KillAllDevices
>> RPy module can not be imported. Please check if your rpy
>> installation supports R 2.7.0. If you have multiple R versions
>> installed, you may need to set RHOME before importing rpy. For
>> example:
>> >>> from rpy_options import set_options
>> >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>> >>> from rpy import *
>> Is there anything I had to do and did not? Is there anything to set up
>> within R?
>> Thanks!
>> Agus
>> Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> LLuis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> email: Agustin.Lobo at ija.csic.es
>> http://www.ija.csic.es/gt/obster
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
