[Qgis-user] Re: Qgis-user Digest, Vol 27, Issue 13
Carson Farmer
cfarmer at uvic.ca
Mon May 12 10:49:06 PDT 2008
Agus,
Unfortunately, the latest R and Rpy versions are not compatible on
Hardy, so the main repositories will be no help to you in this regard.
However, there are two solutions (that I know of):
1) If you are able to, you can regress to an earlier version of R, such
as 2.6.0 or 2.6.2. Rpy works fine for older versions.
2) If you don't mind a little bit of extra work, you can follow the fix
posted by Diwaker Gupta (this is actually for Gutsy, but it still
works...) and a few posts afterwards to get Rpy working with the latest R.
Personally, I use R 2.6.0 and Rpy 1.0.1 (though I think 1.0.2 is the
most recent)
Hope this helps,
Carson
a.k.a. cfarmer on IRC
> No idea, I installed rpy for using manageR. How can I test it? Agus
> Sebastien Vial wrote:
>> > Hi !
>> > Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
>> > Does your RPY works with R 2.7 ?
>> > Seb
>> > 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>>> >> Hi!
>>> >> I have a problem with loading plugin manageR.
>>> >> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>>> >> I get
>>> >> the following message at starting qgis 0.10:
>>> >> Couldn't load plugin "manageR" from ['/home/alobo/.qgis//python/plugins',
>>> >> '/usr/local/share/qgis/python', '/usr/local/share/qgis/python/plugins',
>>> >> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>>> >> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>> >> '/usr/lib/python2.5/lib-dynload', '/usr/local/lib/python2.5/site-packages',
>>> >> '/usr/lib/python2.5/site-packages',
>>> >> '/usr/lib/python2.5/site-packages/Numeric',
>>> >> '/usr/lib/python2.5/site-packages/PIL',
>>> >> '/usr/lib/python2.5/site-packages/gst-0.10',
>>> >> '/var/lib/python-support/python2.5',
>>> >> '/usr/lib/python2.5/site-packages/gtk-2.0',
>>> >> '/var/lib/python-support/python2.5/gtk-2.0']
>>> >> Traceback (most recent call last):
>>> >> File "", line 2, in
>>> >> File "/home/alobo/.qgis//python/plugins/manageR/__init__.py", line 35, in
>>> >> from manageR import manageRPlugin
>>> >> File "/home/alobo/.qgis//python/plugins/manageR/manageR.py", line 40, in
>>> >> import domanageR
>>> >> File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line 39, in
>>> >> from rpy import *
>>> >> File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>>> >> """ % RVERSION)
>>> >> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so: undefined
>>> >> symbol: KillAllDevices
>>> >> RPy module can not be imported. Please check if your rpy
>>> >> installation supports R 2.7.0. If you have multiple R versions
>>> >> installed, you may need to set RHOME before importing rpy. For
>>> >> example:
>>> >> >>> from rpy_options import set_options
>>> >> >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>> >> >>> from rpy import *
>>> >> Is there anything I had to do and did not? Is there anything to set up
>>> >> within R?
>>> >> Thanks!
>>> >> Agus
>>> >> Dr. Agustin Lobo
>>> >> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>> >> LLuis Sole Sabaris s/n
>>> >> 08028 Barcelona
>>> >> Spain
>>> >> Tel. 34 934095410
>>> >> Fax. 34 934110012
>>> >> email: Agustin.Lobo at ija.csic.es
>>> >> http://www.ija.csic.es/gt/obster
>>> >> _______________________________________________
>>> >> Qgis-user mailing list
>>> >> Qgis-user at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> -- Dr. Agustin Lobo Institut de Ciencies de la Terra "Jaume Almera"
> (CSIC) LLuis Sole Sabaris s/n 08028 Barcelona Spain Tel. 34 934095410
> Fax. 34 934110012 email: Agustin.Lobo at ija.csic.es
