[Qgis-user] Re: Qgis-user Digest, Vol 27, Issue 13
    Agustin Lobo
    aloboaleu at gmail.com
    Tue May 13 00:41:11 PDT 2008
Hi!
Rpy 1.0.3 is available since today!
"The primary purpose of
this release is to provide support for R 2.7.0."
But no windows yet (not a problem in my case).
More on:
http://sourceforge.net/mailarchive/forum.php?thread_name=7C8225C0-9810-401A-857F-1B3D6EE4E5F4%40rochester.edu&forum_name=rpy-lis
I'll let you know how it goes with it.
Agus
Carson Farmer wrote:
> Agus,
> Unfortunately, the latest R and  Rpy versions are not compatible on
> Hardy, so the main repositories will be no help to you in this regard.
> However, there are two solutions (that I know of):
> 1) If you are able to, you can regress to an earlier version of R, such
> as 2.6.0 or 2.6.2. Rpy works fine for older versions.
> 2) If you don't mind a little bit of extra work, you can follow the fix
> posted by Diwaker Gupta (this is actually for Gutsy, but it still
> works...) and a few posts afterwards to get Rpy working with the latest R.
> Personally, I use R 2.6.0 and Rpy 1.0.1 (though I think 1.0.2 is the
> most recent)
> Hope this helps,
> Carson
> a.k.a. cfarmer on IRC
>> No idea, I installed rpy for using manageR. How can I test it? Agus
>> Sebastien Vial wrote:
>>> > Hi !
>>> > > Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
>>> > > Does your RPY works with R 2.7 ?
>>> > > Seb
>>> > > 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>> >> Hi!
>>>> >> I have a problem with loading plugin manageR.
>>>> >> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>>>> >> I get
>>>> >> the following message at starting qgis 0.10:
>>>> >> Couldn't load plugin "manageR" from
>>>> ['/home/alobo/.qgis//python/plugins',
>>>> >> '/usr/local/share/qgis/python',
>>>> '/usr/local/share/qgis/python/plugins',
>>>> >> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>>>> >> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>>> >> '/usr/lib/python2.5/lib-dynload',
>>>> '/usr/local/lib/python2.5/site-packages',
>>>> >> '/usr/lib/python2.5/site-packages',
>>>> >> '/usr/lib/python2.5/site-packages/Numeric',
>>>> >> '/usr/lib/python2.5/site-packages/PIL',
>>>> >> '/usr/lib/python2.5/site-packages/gst-0.10',
>>>> >> '/var/lib/python-support/python2.5',
>>>> >> '/usr/lib/python2.5/site-packages/gtk-2.0',
>>>> >> '/var/lib/python-support/python2.5/gtk-2.0']
>>>> >> Traceback (most recent call last):
>>>> >>  File "", line 2, in
>>>> >>  File "/home/alobo/.qgis//python/plugins/manageR/__init__.py",
>>>> line 35, in
>>>> >>  from manageR import manageRPlugin
>>>> >>  File "/home/alobo/.qgis//python/plugins/manageR/manageR.py",
>>>> line 40, in
>>>> >>  import domanageR
>>>> >>  File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py",
>>>> line 39, in
>>>> >>  from rpy import *
>>>> >>  File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>>>> >>  """ % RVERSION)
>>>> >> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so:
>>>> undefined
>>>> >> symbol: KillAllDevices
>>>> >>   RPy module can not be imported. Please check if your rpy
>>>> >>   installation supports R 2.7.0. If you have multiple R versions
>>>> >>   installed, you may need to set RHOME before importing rpy. For
>>>> >>   example:
>>>> >>   >>> from rpy_options import set_options
>>>> >>   >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>>> >>   >>> from rpy import *
>>>> >> Is there anything I had to do and did not? Is there anything to
>>>> set up
>>>> >> within R?
>>>> >> Thanks!
>>>> >> Agus
>>>> >> Dr. Agustin Lobo
>>>> >> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>> >> LLuis Sole Sabaris s/n
>>>> >> 08028 Barcelona
>>>> >> Spain
>>>> >> Tel. 34 934095410
>>>> >> Fax. 34 934110012
>>>> >> email: Agustin.Lobo at ija.csic.es
>>>> >> http://www.ija.csic.es/gt/obster
>>>> >> _______________________________________________
>>>> >> Qgis-user mailing list
>>>> >> Qgis-user at lists.osgeo.org
>>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> -- Dr. Agustin Lobo Institut de Ciencies de la Terra "Jaume Almera"
>> (CSIC) LLuis Sole Sabaris s/n 08028 Barcelona Spain Tel. 34 934095410
>> Fax. 34 934110012 email: Agustin.Lobo at ija.csic.es
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
