[Qgis-user] Re: Qgis-user Digest, Vol 27, Issue 13
Agustin Lobo
aloboaleu at gmail.com
Tue May 13 01:08:53 PDT 2008
ok, just installed Rpy 1.0.3
(BTW, should I have uninstalled 1.02? how?)
and manageR loads
on qgis 0.10 on ubuntu hardy.
Carson, could you provide some directions on how to use it
or point me to any file with some directions?
Should I have R started or should I start it from within
your plugin?
Thanks!
Agus
Agustin Lobo wrote:
> Hi!
> Rpy 1.0.3 is available since today!
> "The primary purpose of
> this release is to provide support for R 2.7.0."
> But no windows yet (not a problem in my case).
> More on:
> http://sourceforge.net/mailarchive/forum.php?thread_name=7C8225C0-9810-401A-857F-1B3D6EE4E5F4%40rochester.edu&forum_name=rpy-lis
> I'll let you know how it goes with it.
> Agus
> Carson Farmer wrote:
>> Agus,
>> Unfortunately, the latest R and Rpy versions are not compatible on
>> Hardy, so the main repositories will be no help to you in this
>> regard. However, there are two solutions (that I know of):
>> 1) If you are able to, you can regress to an earlier version of R,
>> such as 2.6.0 or 2.6.2. Rpy works fine for older versions.
>> 2) If you don't mind a little bit of extra work, you can follow the
>> fix posted by Diwaker Gupta (this is actually for Gutsy, but it still
>> works...) and a few posts afterwards to get Rpy working with the
>> latest R.
>> Personally, I use R 2.6.0 and Rpy 1.0.1 (though I think 1.0.2 is the
>> most recent)
>> Hope this helps,
>> Carson
>> a.k.a. cfarmer on IRC
>>> No idea, I installed rpy for using manageR. How can I test it? Agus
>>> Sebastien Vial wrote:
>>>> > Hi !
>>>> > > Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
>>>> > > Does your RPY works with R 2.7 ?
>>>> > > Seb
>>>> > > 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>>> >> Hi!
>>>>> >> I have a problem with loading plugin manageR.
>>>>> >> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>>>>> >> I get
>>>>> >> the following message at starting qgis 0.10:
>>>>> >> Couldn't load plugin "manageR" from
>>>>> ['/home/alobo/.qgis//python/plugins',
>>>>> >> '/usr/local/share/qgis/python',
>>>>> '/usr/local/share/qgis/python/plugins',
>>>>> >> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>>>>> >> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>>>> >> '/usr/lib/python2.5/lib-dynload',
>>>>> '/usr/local/lib/python2.5/site-packages',
>>>>> >> '/usr/lib/python2.5/site-packages',
>>>>> >> '/usr/lib/python2.5/site-packages/Numeric',
>>>>> >> '/usr/lib/python2.5/site-packages/PIL',
>>>>> >> '/usr/lib/python2.5/site-packages/gst-0.10',
>>>>> >> '/var/lib/python-support/python2.5',
>>>>> >> '/usr/lib/python2.5/site-packages/gtk-2.0',
>>>>> >> '/var/lib/python-support/python2.5/gtk-2.0']
>>>>> >> Traceback (most recent call last):
>>>>> >> File "", line 2, in
>>>>> >> File "/home/alobo/.qgis//python/plugins/manageR/__init__.py",
>>>>> line 35, in
>>>>> >> from manageR import manageRPlugin
>>>>> >> File "/home/alobo/.qgis//python/plugins/manageR/manageR.py",
>>>>> line 40, in
>>>>> >> import domanageR
>>>>> >> File "/home/alobo/.qgis//python/plugins/manageR/domanageR.py",
>>>>> line 39, in
>>>>> >> from rpy import *
>>>>> >> File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>>>>> >> """ % RVERSION)
>>>>> >> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so:
>>>>> undefined
>>>>> >> symbol: KillAllDevices
>>>>> >> RPy module can not be imported. Please check if your rpy
>>>>> >> installation supports R 2.7.0. If you have multiple R versions
>>>>> >> installed, you may need to set RHOME before importing rpy. For
>>>>> >> example:
>>>>> >> >>> from rpy_options import set_options
>>>>> >> >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>>>> >> >>> from rpy import *
>>>>> >> Is there anything I had to do and did not? Is there anything to
>>>>> set up
>>>>> >> within R?
>>>>> >> Thanks!
>>>>> >> Agus
>>>>> >> Dr. Agustin Lobo
>>>>> >> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>>> >> LLuis Sole Sabaris s/n
>>>>> >> 08028 Barcelona
>>>>> >> Spain
>>>>> >> Tel. 34 934095410
>>>>> >> Fax. 34 934110012
>>>>> >> email: Agustin.Lobo at ija.csic.es
>>>>> >> http://www.ija.csic.es/gt/obster
>>>>> >> _______________________________________________
>>>>> >> Qgis-user mailing list
>>>>> >> Qgis-user at lists.osgeo.org
>>>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> -- Dr. Agustin Lobo Institut de Ciencies de la Terra "Jaume Almera"
>>> (CSIC) LLuis Sole Sabaris s/n 08028 Barcelona Spain Tel. 34 934095410
>>> Fax. 34 934110012 email: Agustin.Lobo at ija.csic.es
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
