[Qgis-user] Re: Qgis-user Digest, Vol 27, Issue 13
Carson Farmer
cfarmer at uvic.ca
Tue May 13 14:07:03 PDT 2008
This is certainly where I would like to see manageR go someday! But
unfortunately this would entail programming in C, which requires someone
much more skilled than myself!
For now I simply use it instead of jumping between the two applications...
Your suggestion about displaying sp objects was a topic of discussion
for the QGIS bridge2R team (of which I am a member), but we ended up
putting this aside, as we felt that the average QGIS user would rather
have all the R stuff happen 'behind the scenes' on their input vector
layers directly, rather than knowingly interacting with R. I tend to
agree with this idea for that particular project, but for manageR,
displaying sp objects would be great! I think in the end this would
require an ogr/gdal driver for sp objects as Barry Rowlingson has
previously suggested here, and in the r-sig-geo lists.
I have started to look at some brushing and linking functions using the
iPlots R package, and should hopefully be able to implement some of
these things in the future...?
Carson
Agustin Lobo wrote:
> Thanks Carson, just knowing that this is an R console is enough.
> Now, after making a simple plot(), I'm just dreaming: if we could
> display sp objects directly, not only avoiding the intermediate
> shp file but being able of plotting columns of the dataframe
> as statistical graphics in R...
> and soon being able to interact between the R plot and the
> geographic display (a linked brushing, for example), tools
> like in GeoDa but with a real GIS diaplay...
> Great job!
> (I'm forwarding the r-sig-geo list just for them
> to know your developments)
> Agus
> Carson Farmer wrote:
>> Agustin Lobo wrote:
>>> ok, just installed Rpy 1.0.3
>>> (BTW, should I have uninstalled 1.02? how?)
>>> and manageR loads
>>> on qgis 0.10 on ubuntu hardy.
>>> Carson, could you provide some directions on how to use it
>>> or point me to any file with some directions?
>> The plugin dialog can be treated like the R console itself. So
>> whatever commands you would type into R, you can do in manageR (just
>> make sure you use '<-' when assigning variables etc. as manageR
>> doesn't like you to use '='). I have an updated manageR version
>> which, in addition to making it easier to load spatial data, also
>> makes it very easy to save R spatial objects as shapefiles and
>> automatically load them into QGIS. This will be up on my repository
>> soon (I will post a notice to this list when it is).
>> As for directions on how to use manageR, I have not really come up
>> with anything yet, but I will try to post something soon with a basic
>> how to and some screen shots or something.
>> Hope this is enough to get you started!
>> Carson
>>> Should I have R started or should I start it from within
>>> your plugin?
>>> Thanks!
>>> Agus
>>> Agustin Lobo wrote:
>>>> Hi!
>>>> Rpy 1.0.3 is available since today!
>>>> "The primary purpose of
>>>> this release is to provide support for R 2.7.0."
>>>> But no windows yet (not a problem in my case).
>>>> More on:
>>>> http://sourceforge.net/mailarchive/forum.php?thread_name=7C8225C0-9810-401A-857F-1B3D6EE4E5F4%40rochester.edu&forum_name=rpy-lis
>>>> I'll let you know how it goes with it.
>>>> Agus
>>>>> Agus,
>>>>> Unfortunately, the latest R and Rpy versions are not compatible
>>>>> on Hardy, so the main repositories will be no help to you in this
>>>>> regard. However, there are two solutions (that I know of):
>>>>> 1) If you are able to, you can regress to an earlier version of R,
>>>>> such as 2.6.0 or 2.6.2. Rpy works fine for older versions.
>>>>> 2) If you don't mind a little bit of extra work, you can follow
>>>>> the fix posted by Diwaker Gupta (this is actually for Gutsy, but
>>>>> it still works...) and a few posts afterwards to get Rpy working
>>>>> with the latest R.
>>>>> Personally, I use R 2.6.0 and Rpy 1.0.1 (though I think 1.0.2 is
>>>>> the most recent)
>>>>> Hope this helps,
>>>>> Carson
>>>>> a.k.a. cfarmer on IRC
>>>>>> No idea, I installed rpy for using manageR. How can I test it?
>>>>>> Agus Sebastien Vial wrote:
>>>>>>> > Hi !
>>>>>>> > > Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
>>>>>>> > > Does your RPY works with R 2.7 ?
>>>>>>> > > Seb
>>>>>>> > > 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>>>>>> >> Hi!
>>>>>>>> >> I have a problem with loading plugin manageR.
>>>>>>>> >> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>>>>>>>> >> I get
>>>>>>>> >> the following message at starting qgis 0.10:
>>>>>>>> >> Couldn't load plugin "manageR" from
>>>>>>>> ['/home/alobo/.qgis//python/plugins',
>>>>>>>> >> '/usr/local/share/qgis/python',
>>>>>>>> '/usr/local/share/qgis/python/plugins',
>>>>>>>> >> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>>>>>>>> >> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>>>>>>> >> '/usr/lib/python2.5/lib-dynload',
>>>>>>>> '/usr/local/lib/python2.5/site-packages',
>>>>>>>> >> '/usr/lib/python2.5/site-packages',
>>>>>>>> >> '/usr/lib/python2.5/site-packages/Numeric',
>>>>>>>> >> '/usr/lib/python2.5/site-packages/PIL',
>>>>>>>> >> '/usr/lib/python2.5/site-packages/gst-0.10',
>>>>>>>> >> '/var/lib/python-support/python2.5',
>>>>>>>> >> '/usr/lib/python2.5/site-packages/gtk-2.0',
>>>>>>>> >> '/var/lib/python-support/python2.5/gtk-2.0']
>>>>>>>> >> Traceback (most recent call last):
>>>>>>>> >> File "", line 2, in
>>>>>>>> >> File
>>>>>>>> "/home/alobo/.qgis//python/plugins/manageR/__init__.py", line
>>>>>>>> 35, in
>>>>>>>> >> from manageR import manageRPlugin
>>>>>>>> >> File
>>>>>>>> "/home/alobo/.qgis//python/plugins/manageR/manageR.py", line
>>>>>>>> 40, in
>>>>>>>> >> import domanageR
>>>>>>>> >> File
>>>>>>>> "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line
>>>>>>>> 39, in
>>>>>>>> >> from rpy import *
>>>>>>>> >> File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>>>>>>>> >> """ % RVERSION)
>>>>>>>> >> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so:
>>>>>>>> undefined
>>>>>>>> >> symbol: KillAllDevices
>>>>>>>> >> RPy module can not be imported. Please check if your rpy
>>>>>>>> >> installation supports R 2.7.0. If you have multiple R
>>>>>>>> versions
>>>>>>>> >> installed, you may need to set RHOME before importing rpy.
>>>>>>>> For
>>>>>>>> >> example:
>>>>>>>> >> >>> from rpy_options import set_options
>>>>>>>> >> >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>>>>>>> >> >>> from rpy import *
>>>>>>>> >> Is there anything I had to do and did not? Is there anything
>>>>>>>> to set up
>>>>>>>> >> within R?
>>>>>>>> >> Thanks!
>>>>>>>> >> Agus
>>>>>>>> >> Dr. Agustin Lobo
>>>>>>>> >> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>>>>>> >> LLuis Sole Sabaris s/n
>>>>>>>> >> 08028 Barcelona
>>>>>>>> >> Spain
>>>>>>>> >> Tel. 34 934095410
>>>>>>>> >> Fax. 34 934110012
>>>>>>>> >> email: Agustin.Lobo at ija.csic.es
>>>>>>>> >> http://www.ija.csic.es/gt/obster
>>>>>>>> >> _______________________________________________
>>>>>>>> >> Qgis-user mailing list
>>>>>>>> >> Qgis-user at lists.osgeo.org
>>>>>>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> -- Dr. Agustin Lobo Institut de Ciencies de la Terra "Jaume
>>>>>> Almera" (CSIC) LLuis Sole Sabaris s/n 08028 Barcelona Spain Tel.
>>>>>> 34 934095410 Fax. 34 934110012 email: Agustin.Lobo at ija.csic.es
