[Qgis-user] Re: Qgis-user Digest, Vol 27, Issue 13
Agustin Lobo Agustin.Lobo at ija.csic.es
Tue May 13 13:37:22 PDT 2008
Thanks Carson, just knowing that this is an R console is enough.
Now, after making a simple plot(), I'm just dreaming: if we could
display sp objects directly, not only avoiding the intermediate
shp file but being able of plotting columns of the dataframe
as statistical graphics  in R...
and soon being able to interact between the R plot and the
geographic display (a linked brushing, for example), tools
like in GeoDa but with a real GIS diaplay...
Great job!
(I'm forwarding the r-sig-geo list just for them
to know your developments)
Agus
Carson Farmer wrote:
> Agustin Lobo wrote:
>> ok, just installed Rpy 1.0.3
>> (BTW, should I have uninstalled 1.02? how?)
>> and manageR loads
>> on qgis 0.10 on ubuntu hardy.
>> Carson, could you provide some directions on how to use it
>> or point me to any file with some directions?
> The plugin dialog can be treated like the R console itself. So whatever
> commands you would type into R, you can do in manageR (just make sure
> you use '<-' when assigning variables etc. as manageR doesn't like you
> to use '='). I have an updated manageR version which, in addition to
> making it easier to load spatial data, also makes it very easy to save R
> spatial objects as shapefiles and automatically load them into QGIS.
> This will be up on my repository soon (I will post a notice to this list
> when it is).
> As for directions on how to use manageR, I have not really come up with
> anything yet, but I will try to post something soon with a basic how to
> and some screen shots or something.
> Hope this is enough to get you started!
> Carson
>> Should I have R started or should I start it from within
>> your plugin?
>> Thanks!
>> Agus
>> Agustin Lobo wrote:
>>> Hi!
>>> Rpy 1.0.3 is available since today!
>>> "The primary purpose of
>>> this release is to provide support for R 2.7.0."
>>> But no windows yet (not a problem in my case).
>>> More on:
>>> http://sourceforge.net/mailarchive/forum.php?thread_name=7C8225C0-9810-401A-857F-1B3D6EE4E5F4%40rochester.edu&forum_name=rpy-lis
>>> I'll let you know how it goes with it.
>>> Agus
>>>> Agus,
>>>> Unfortunately, the latest R and  Rpy versions are not compatible on
>>>> Hardy, so the main repositories will be no help to you in this
>>>> regard.  However, there are two solutions (that I know of):
>>>> 1) If you are able to, you can regress to an earlier version of R,
>>>> such as 2.6.0 or 2.6.2. Rpy works fine for older versions.
>>>> 2) If you don't mind a little bit of extra work, you can follow the
>>>> fix posted by Diwaker Gupta (this is actually for Gutsy, but it
>>>> still works...) and a few posts afterwards to get Rpy working with
>>>> the latest R.
>>>> Personally, I use R 2.6.0 and Rpy 1.0.1 (though I think 1.0.2 is the
>>>> most recent)
>>>> Hope this helps,
>>>> Carson
>>>> a.k.a. cfarmer on IRC
>>>>> No idea, I installed rpy for using manageR. How can I test it? Agus
>>>>> Sebastien Vial wrote:
>>>>>> > Hi !
>>>>>> > > Here it works but with R 2.6.1 (and the RPY build for R 2.6.1)
>>>>>> > > Does your RPY works with R 2.7 ?
>>>>>> > > Seb
>>>>>> > > 2008/5/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>>>>> >> Hi!
>>>>>>> >> I have a problem with loading plugin manageR.
>>>>>>> >> I have R 2.7.0, rpy 1.0.2 , python and numpy on ubuntu hardy.
>>>>>>> >> I get
>>>>>>> >> the following message at starting qgis 0.10:
>>>>>>> >> Couldn't load plugin "manageR" from
>>>>>>> ['/home/alobo/.qgis//python/plugins',
>>>>>>> >> '/usr/local/share/qgis/python',
>>>>>>> '/usr/local/share/qgis/python/plugins',
>>>>>>> >> '/usr/lib/python25.zip', '/usr/lib/python2.5',
>>>>>>> >> '/usr/lib/python2.5/plat-linux2', '/usr/lib/python2.5/lib-tk',
>>>>>>> >> '/usr/lib/python2.5/lib-dynload',
>>>>>>> '/usr/local/lib/python2.5/site-packages',
>>>>>>> >> '/usr/lib/python2.5/site-packages',
>>>>>>> >> '/usr/lib/python2.5/site-packages/Numeric',
>>>>>>> >> '/usr/lib/python2.5/site-packages/PIL',
>>>>>>> >> '/usr/lib/python2.5/site-packages/gst-0.10',
>>>>>>> >> '/var/lib/python-support/python2.5',
>>>>>>> >> '/usr/lib/python2.5/site-packages/gtk-2.0',
>>>>>>> >> '/var/lib/python-support/python2.5/gtk-2.0']
>>>>>>> >> Traceback (most recent call last):
>>>>>>> >>  File "", line 2, in
>>>>>>> >>  File "/home/alobo/.qgis//python/plugins/manageR/__init__.py",
>>>>>>> line 35, in
>>>>>>> >>  from manageR import manageRPlugin
>>>>>>> >>  File "/home/alobo/.qgis//python/plugins/manageR/manageR.py",
>>>>>>> line 40, in
>>>>>>> >>  import domanageR
>>>>>>> >>  File
>>>>>>> "/home/alobo/.qgis//python/plugins/manageR/domanageR.py", line
>>>>>>> 39, in
>>>>>>> >>  from rpy import *
>>>>>>> >>  File "/usr/lib/python2.5/site-packages/rpy.py", line 134, in
>>>>>>> >>  """ % RVERSION)
>>>>>>> >> RuntimeError: /usr/lib/python2.5/site-packages/_rpy2070.so:
>>>>>>> undefined
>>>>>>> >> symbol: KillAllDevices
>>>>>>> >>   RPy module can not be imported. Please check if your rpy
>>>>>>> >>   installation supports R 2.7.0. If you have multiple R versions
>>>>>>> >>   installed, you may need to set RHOME before importing rpy. For
>>>>>>> >>   example:
>>>>>>> >>   >>> from rpy_options import set_options
>>>>>>> >>   >>> set_options(RHOME='c:/progra~1/r/rw2011/')
>>>>>>> >>   >>> from rpy import *
>>>>>>> >> Is there anything I had to do and did not? Is there anything
>>>>>>> to set up
>>>>>>> >> within R?
>>>>>>> >> Thanks!
>>>>>>> >> Agus
>>>>>>> >> Dr. Agustin Lobo
>>>>>>> >> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>>>>> >> LLuis Sole Sabaris s/n
>>>>>>> >> 08028 Barcelona
>>>>>>> >> Spain
>>>>>>> >> Tel. 34 934095410
>>>>>>> >> Fax. 34 934110012
>>>>>>> >> email: Agustin.Lobo at ija.csic.es
>>>>>>> >> http://www.ija.csic.es/gt/obster
>>>>>>> >> _______________________________________________
>>>>>>> >> Qgis-user mailing list
>>>>>>> >> Qgis-user at lists.osgeo.org
>>>>>>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> -- Dr. Agustin Lobo Institut de Ciencies de la Terra "Jaume Almera"
>>>>> (CSIC) LLuis Sole Sabaris s/n 08028 Barcelona Spain Tel. 34
>>>>> 934095410 Fax. 34 934110012 email: Agustin.Lobo at ija.csic.es
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
