[Qgis-user] No coordinate capture in preview2 for ubuntu
Tim Sutton
tim at linfiniti.com
Wed Nov 12 06:50:29 PST 2008
Hi
Thats strange. Can you look in your filesystem and see if its present in:
/usr/lib/qgis/libcoordinatecaptureplugin.so
Are you using the Ubuntu packages? If yes and its not there then I
suspect its missing in the debian packaging stuff. Juergen can you add
it in there if its missing?
Regards
Tim
2008/11/12 Agustin Lobo <Agustin.Lobo at ija.csic.es>:
> But unfortunately it's not or cannot find it,
> see the attachment (probably deleted for the list)
> I have all "by default" plugins activated except
> Value tool and Pypostgis, which cause errors.
> Agus
> Tim Sutton wrote:
>> Hi
>> 2008/11/12 Agustin Lobo <aloboaleu at gmail.com>:
>>> Why there is no coordinate capture tool
>>> in the preview2 for ubuntu?
>> It should be there - you probably just need to enable it in the plugin
>> manager....
>> Regards
>> Tim
>>> Thanks
>>> Agus
>>> Dr. Agustin Lobo
>>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>> LLuis Sole Sabaris s/n
>>> 08028 Barcelona
>>> Spain
>>> Tel. 34 934095410
>>> Fax. 34 934110012
>>> email: Agustin.Lobo at ija.csic.es
>>> http://www.ija.csic.es/gt/obster
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Agustin Lobo
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
