[Qgis-user] No coordinate capture in preview2 for ubuntu
Agustin Lobo Agustin.Lobo at ija.csic.es
Wed Nov 12 07:09:38 PST 2008
Tim,
it's not there:
alobo at alobo-laptop:/usr/lib/qgis$ ls *.so
libcopyrightlabelplugin.so    libgrassplugin.so
libpostgresprovider.so
libdelimitedtextplugin.so     libgrassprovider.so
libscalebarplugin.so
libdelimitedtextprovider.so   libgridmakerplugin.so      libspitplugin.so
libdxf2shpconverterplugin.so  libinterpolationplugin.so  libwfsplugin.so
libevis.so                    libmemoryprovider.so       libwfsprovider.so
libgeorefplugin.so            libnortharrowplugin.so     libwmsprovider.so
libgpsimporterplugin.so       libogrconverterplugin.so
libgpxprovider.so             libogrprovider.so
I'm using the preview2 for ubuntu 8.04 installed from the
http://ppa.launchpad.net/jef-norbit/ubuntu
repository
BTW, are not the directions for ubuntu in
http://download.qgis.org/downloads.rhtml
wrong?
It says:
Add these lines to your /etc/apt/sources.list deb
http://ppa.launchpad.net/jef-norbit/ubuntu hardy main deb-src
http://ppa.launchpad.net/jef-norbit/ubuntu hardy main Then do sudo
apt-get update sudo apt-get install qgis
should not be:
Add these lines to your /etc/apt/sources.list:
deb http://ppa.launchpad.net/jef-norbit/ubuntu hardy main
deb-src http://ppa.launchpad.net/jef-norbit/ubuntu hardy main
Then uninstall (select complete remove in Synaptic) your previous qgis
version and install with synaptic or do:
sudo apt-get update
Agus
Tim Sutton wrote:
> Hi
> Thats strange. Can you look in your filesystem and see if its present in:
> /usr/lib/qgis/libcoordinatecaptureplugin.so
> Are you using the Ubuntu packages? If yes and its not there then I
> suspect its missing in the debian packaging stuff. Juergen can you add
> it in there if its missing?
> Regards
> Tim
> 2008/11/12 Agustin Lobo <Agustin.Lobo at ija.csic.es>:
>> But unfortunately it's not or cannot find it,
>> see the attachment (probably deleted for the list)
>> I have all "by default" plugins activated except
>> Value tool and Pypostgis, which cause errors.
>> Agus
>> Tim Sutton wrote:
>>> Hi
>>> 2008/11/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>> Why there is no coordinate capture tool
>>>> in the preview2 for ubuntu?
>>> It should be there - you probably just need to enable it in the plugin
>>> manager....
>>> Regards
>>> Tim
>>>> Thanks
>>>> Agus
>>>> Dr. Agustin Lobo
>>>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>> LLuis Sole Sabaris s/n
>>>> 08028 Barcelona
>>>> Spain
>>>> Tel. 34 934095410
>>>> Fax. 34 934110012
>>>> email: Agustin.Lobo at ija.csic.es
>>>> http://www.ija.csic.es/gt/obster
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Dr. Agustin Lobo
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
