[Qgis-user] No coordinate capture in preview2 for ubuntu
Agustin Lobo Agustin.Lobo at ija.csic.es
Wed Nov 12 09:33:20 PST 2008
After installing the newest package for ubuntu
(1.0preview17)
the Coordinate Capture is there.
Two plugins that are installed by default still do not work:
Value tool
   File "/home/alobo/.qgis//python/plugins/valuetool/valuewidget.py",
line 98, in printValue
     layer = self.canvas.getZpos(i)
AttributeError: getZpos
PyPostGis
   File "", line 1, in
   File "/home/alobo/.qgis//python/plugins/pypostgis/Pypostgis.py", line
22, in initGui
     self.action = QAction(QIcon(":pypostgis.png"), "Python Postgis
SQL", self.iface.getMainWindow())
AttributeError: getMainWindow
Thanks a lot to the so many that make all this magic
possible.
Agus
Tim Sutton wrote:
> Hi
> Thats strange. Can you look in your filesystem and see if its present in:
> /usr/lib/qgis/libcoordinatecaptureplugin.so
> Are you using the Ubuntu packages? If yes and its not there then I
> suspect its missing in the debian packaging stuff. Juergen can you add
> it in there if its missing?
> Regards
> Tim
> 2008/11/12 Agustin Lobo <Agustin.Lobo at ija.csic.es>:
>> But unfortunately it's not or cannot find it,
>> see the attachment (probably deleted for the list)
>> I have all "by default" plugins activated except
>> Value tool and Pypostgis, which cause errors.
>> Agus
>> Tim Sutton wrote:
>>> Hi
>>> 2008/11/12 Agustin Lobo <aloboaleu at gmail.com>:
>>>> Why there is no coordinate capture tool
>>>> in the preview2 for ubuntu?
>>> It should be there - you probably just need to enable it in the plugin
>>> manager....
>>> Regards
>>> Tim
>>>> Thanks
>>>> Agus
>>>> Dr. Agustin Lobo
>>>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>>>> LLuis Sole Sabaris s/n
>>>> 08028 Barcelona
>>>> Spain
>>>> Tel. 34 934095410
>>>> Fax. 34 934110012
>>>> email: Agustin.Lobo at ija.csic.es
>>>> http://www.ija.csic.es/gt/obster
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Dr. Agustin Lobo
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
