[Qgis-user] No coordinate capture in preview2 for ubuntu
Jürgen E. Fischer
jef at norbit.de
Wed Nov 12 16:39:21 PST 2008
Hi Agus,
On Wed, 12. Nov 2008 at 18:33:20 +0100, Agustin Lobo wrote:
> Two plugins that are installed by default still do not work:
You probably installed them in your home directory (~/.qgis).
The only python plugins installed with qgis are plugin installer and
mapserver export - and those should be updated to match the current API.
All others are doomed to fail as they can't possibly keep up until the
API settles - which will happen when we finally release 1.0.
If you are lucky you can get an updated copy using said plugin
installer.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
