[Qgis-user] print legend in the image
Tim Sutton
tim at linfiniti.com
Wed Nov 12 23:13:46 PST 2008
Hi Alexandre
If it is a shapefile, you need to create a thematic map based on some
attribute in the attribute table if you want to see multiple colours.
This is explained I think in the manual (its for an older version but
should still apply for your use case):
http://download.osgeo.org/qgis/doc/manual/qgis-0.9.1_user_guide_en.pdf
The short version is to higlight the layer in the legend and then use
the
Layer -> Properties
menu option to bring up the layer properties (you can also double click
the legend entry to bring up the properties).
Now click the Symbology tab and start to play around with the options
you find there. You will probably want to use 'Unique', 'Graduated' or
'Continuous' options to get a nice range of colours in your map.
Hope that helps!
Regards
Tim
On Wed, 2008-11-12 at 16:23 -0300, Alexandre Santos wrote:
> Hi all,
> Have a file (format shape) com diferrents type of colors.
> How can add a legend in a image in the qgis?
> Tranks.
> SECRETARIA DE ESTADO DO MEIO AMBIENTE E DOS RECURSOS HÍDRICOS
> DIRETORIA DE METEOROLOGIA
> ALEXANDRE S. DOS SANTOS
> TEL.: 82-33152686
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081113/8adcf6ce/attachment.sig>
