[Qgis-user] Win qgis1.0preview2 crashes
Agustin Lobo
Agustin.Lobo at ija.csic.es
Fri Nov 14 02:49:08 PST 2008
Thank you all for the answers:
1. Re-installing windows: not being a windows user, I'd rather
get another PC than re-installing windows. It's true that qgis preview2
works fine on other win computers (even the old one I have at home), but
it's also true that other programs work fine on this laptop and that I
would have to reinstall too many things.
2. Registry cleaning: looks feasible. I have a program
called registry cleaner, what should I look for?
3. "video driver; I'd look for an updated version": mine is Mobile Intel
945GM Express Chipset 6.14.10.4436 28/11/2005 and have not found
anything better/more modern.
May be the cause is that I have SP2 and not SP3? (I'm reluctant
to upgrade to SP3 as this caused lots of problems in
another computer)
Agus
Goyo wrote:
> In case it is a configuration issue, deleting directories in Windows
> won't work because it's stored in the registry. Maybe some registry
> cleaning can help.
> El jue, 13-11-2008 a las 16:17 +0100, Agustin Lobo escribió:
>> Dear list,
>> Regarding the windows version, I have the same problem with preview2
>> than I had with preview1 on a winXP laptop:
>> after few operations, QGIS always crashes. In
>> particular, after selecting the Properties tab of any
>> layer. I've uninstalled, deleted the directory, rebooted,
>> installed again... same problem.
>> This problem does not occur on other win machines
>> (although I've not been able to test on many, I'm not
>> a windows user most of the time). I've run the program
>> from a console, but no messages are printed to it in
>> the win version.
>> Any clue on what could be happening? It's annoying, as
>> this is the laptop that I use most of the time, and some
>> people want to see qgis running on win. The same
>> laptop runs ubuntu 8.04, no problem there.
>> Thanks!
>> Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
