[Qgis-user] Win qgis1.0preview2 crashes
Goyo
goyodiaz at gmail.com
Fri Nov 14 15:53:51 PST 2008
I found this sometime ago and deleting it solved a problem with toolbars
configuration[1]. Maybe it helps you.
/hkcu/software/quantumgis
[1] http://lists.osgeo.org/pipermail/qgis-user/2008-February/002339.html
El vie, 14-11-2008 a las 11:49 +0100, Agustin Lobo escribió:
> Thank you all for the answers:
> 1. Re-installing windows: not being a windows user, I'd rather
> get another PC than re-installing windows. It's true that qgis preview2
> works fine on other win computers (even the old one I have at home), but
> it's also true that other programs work fine on this laptop and that I
> would have to reinstall too many things.
> 2. Registry cleaning: looks feasible. I have a program
> called registry cleaner, what should I look for?
> 3. "video driver; I'd look for an updated version": mine is Mobile Intel
> 945GM Express Chipset 6.14.10.4436 28/11/2005 and have not found
> anything better/more modern.
> May be the cause is that I have SP2 and not SP3? (I'm reluctant
> to upgrade to SP3 as this caused lots of problems in
> another computer)
> Agus
> Goyo wrote:
> > In case it is a configuration issue, deleting directories in Windows
> > won't work because it's stored in the registry. Maybe some registry
> > cleaning can help.
> > El jue, 13-11-2008 a las 16:17 +0100, Agustin Lobo escribió:
> >> Dear list,
> >> Regarding the windows version, I have the same problem with preview2
> >> than I had with preview1 on a winXP laptop:
> >> after few operations, QGIS always crashes. In
> >> particular, after selecting the Properties tab of any
> >> layer. I've uninstalled, deleted the directory, rebooted,
> >> installed again... same problem.
> >> This problem does not occur on other win machines
> >> (although I've not been able to test on many, I'm not
> >> a windows user most of the time). I've run the program
> >> from a console, but no messages are printed to it in
> >> the win version.
> >> Any clue on what could be happening? It's annoying, as
> >> this is the laptop that I use most of the time, and some
> >> people want to see qgis running on win. The same
> >> laptop runs ubuntu 8.04, no problem there.
> >> Thanks!
> >> Agus
