[Qgis-user] Some extra North Arrows :-)
Nikos Alexandris
nikos.alexandris at uranus.uni-freiburg.de
Fri Nov 14 18:24:54 PST 2008
Dear QGIS community,
I've scratched some "north arrows" (using inkscape, based on one of
defaults) that can be used as a point symbol. They are simple .svg files
(including one file called northarrow_source.svg which can be used for
further editing).
Hope you also like the "rotation field" and "area scale field" options
under Layer Properties, Point Symbol as I do. For example they can be
used with an "aspect" and an "area" column of a point-vector's attribute
table. Hopefully you enjoy those options as I do.
Cheers, Nikos
1. Decompress the zip file
2. Rename if necessary (that is if it happens that you already have
added extra north arrows and you don't want to overwrite anything - if
you just have the defaults skip this and worry about it in the future
when your northarrow collection becomes bigger ;-).
3. Copy/Move the files (except of the northarrow_source.svg) to the
directory "/usr/local/share/qgis/svg/north_arrows/". This steps needs
sudo (...sorry, I don't know what should be the corresponding folder in
windows).
4. Launch qgis and test/enjoy :-)
Screenshots at:
http://www.imageshack.gr/view.php?file=n70dtdthvljo3yms0mmy.jpeg
http://www.imageshack.gr/view.php?file=ep4icmtn5egof2swjz6w.jpeg
http://www.imageshack.gr/view.php?file=4rmcgkfk96n2lwqtknhd.jpeg
http://www.imageshack.gr/view.php?file=jb7na2w1ucrmjrwxf0hx.jpeg
http://www.imageshack.gr/view.php?file=in0fj7gwwts7khqf2gth.jpeg
http://www.imageshack.gr/view.php?file=3l2l2ysed33d9nj15cmf.jpeg
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081115/2161c7f6/attachment.zip>
