[Qgis-user] Some extra North Arrows :-)
Tim Sutton
tim at linfiniti.com
Fri Nov 14 22:14:54 PST 2008
Hi Nikos
Thanks for this. Just to be clear are you making your work available for
inclusion into QGIS source tree? If so I will look at adding your icons
because it would be useful to have some direction arrows available by
default to go along with Magnus' symbol rotation work.
Regards
Tim
On Sat, 2008-11-15 at 03:24 +0100, Nikos Alexandris wrote:
> Dear QGIS community,
> I've scratched some "north arrows" (using inkscape, based on one of
> defaults) that can be used as a point symbol. They are simple .svg files
> (including one file called northarrow_source.svg which can be used for
> further editing).
> Hope you also like the "rotation field" and "area scale field" options
> under Layer Properties, Point Symbol as I do. For example they can be
> used with an "aspect" and an "area" column of a point-vector's attribute
> table. Hopefully you enjoy those options as I do.
> Cheers, Nikos
> 1. Decompress the zip file
> 2. Rename if necessary (that is if it happens that you already have
> added extra north arrows and you don't want to overwrite anything - if
> you just have the defaults skip this and worry about it in the future
> when your northarrow collection becomes bigger ;-).
> 3. Copy/Move the files (except of the northarrow_source.svg) to the
> directory "/usr/local/share/qgis/svg/north_arrows/". This steps needs
> sudo (...sorry, I don't know what should be the corresponding folder in
> windows).
> 4. Launch qgis and test/enjoy :-)
> Screenshots at:
> http://www.imageshack.gr/view.php?file=n70dtdthvljo3yms0mmy.jpeg
> http://www.imageshack.gr/view.php?file=ep4icmtn5egof2swjz6w.jpeg
> http://www.imageshack.gr/view.php?file=4rmcgkfk96n2lwqtknhd.jpeg
> http://www.imageshack.gr/view.php?file=jb7na2w1ucrmjrwxf0hx.jpeg
> http://www.imageshack.gr/view.php?file=in0fj7gwwts7khqf2gth.jpeg
> http://www.imageshack.gr/view.php?file=3l2l2ysed33d9nj15cmf.jpeg
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Visit http://linfiniti.com to find out about:
* QGIS programming services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081115/ba38b601/attachment.sig>
