[Qgis-user] Select several layers at once?
Tim Sutton tim at linfiniti.com
Fri Nov 14 21:45:28 PST 2008
Hi
On Fri, 2008-11-14 at 02:23 +0100, Nikos Alexandris wrote:
> > > Dear QGIS community,
> > > I have loaded more than 200 aerial photos and I would like to group
> > > them... but not by dragging each of them in a group of course.
> > > Shift and/or Control selection does not work. And I can't find any
> > > "layer selection" tool on the menu. Is it possible to perform this with
> > > a (python) command at least?
In theory a 'group maker' plugin could be created to do this. The reason
we dont support multiselection in the legend is that some tools /
functions refer to the currently selected legend item and we need to
write appropriate routines to manage cases where more than one layer is
highlighted. This is mostly just legwork, but its not on the cards for
1.0.0 since we are in feature freeze. Be sure to add it as an
enhancement request in the bug queue.
> > > Wouldn't it be a nice feature?
> > > Thank you, Nikos
> > I agree it would be a good feaure.
> > A quick hack for now might be to save the project and edit the project
> > file in a text editor. Make an example and compare on a small set of files.
> I'll have a look at the project files. Thanks for the hint.
> > Note - It's only a guess at a hack.
> > Alex
> Furthermore,
> wasn't there (back in earlier QGIS versions) a "duplicate layer" option
> in the "right-click" menu on (at least) vector layer? Why should I not
> to (re)load a shapefile for instance if I want to compare various
> symbology settings?
I cant recall us ever having that feature but once again should not be
difficult to implement at some stage post 1.0.0.
Regards
Tim
> Kind regards, Nikos
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting & Support Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081115/655ba676/attachment.sig>
