[Qgis-user] Feature enhancement/request for QGIS digitizing toolbox
maning sambale emmanuel.sambale at gmail.com
Mon Nov 17 00:11:22 PST 2008
On 11/17/08, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
>> I use QGIS extensively for digitizing.  Hope this request is valid as
>> an ehancement to QGIS digitizing tools.
>> 1. Stream-mode digitizing
> I wonder if stream-mode is really that useful. In my experience, at least
> when working with mouse - stream-mode digitizing is not very accurate and
> creates not-very optimal results.
> It might be different with a wacom-like tablet and a pen, though.
> Are you using one of those digitizing pens?
No, I don't use digitizing pens.
Generalizing lines from stream-mode digitizing can be easily edited
with generalize tools in GRASS.
>> 2. Adding regular polygons (ala-CAD) like arcs and rectangles
> arcs would be very useful. I would also like to see better arc-support in
> open source GIS - but the problem is that all the underlying libraries (at
> least ogr and proj, I am not sure about geos) do not support arcs and
> other curves. This means that arcs probably at the current time have to be
> transformed into regular polygons with lots of vertices.
That could be a work-around.
>> Maybe we can get some inspiration from JOSM (OSM's java editor)
> yes, maybe.
> Andreas
Note:  While in many ways I am satisfied with the existing digitizing
tools, the above feature/enhancement is an often requested feature
when I introduce QGIS/GRASS to many colleagues.  Especially NGOs
working with geospatial data.
Thank you for looking into this.
cheers,
maning
> Andreas Neumann
> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
> Email: a.neumann at carto.net, Web:
> * http://www.carto.net/ (Carto and SVG resources)
> * http://www.carto.net/neumann/ (personal page)
> * http://www.svgopen.org/ (SVG Open Conference)
> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com/ |
| _)_/L I http://epsg4253.wordpress.com/ |
