[Qgis-user] Big sharing problem - Slow when data are shared in more than one user - QGIS 0.11
Michael Toews
mwtoews at sfu.ca
Thu Nov 27 08:48:53 PST 2008
Hi Fran,
Just a related thought, if you haven't checked out PostGIS, you might
want to consider it. I've brought it into my workplace, and now we have
several people using the same data set (from different offices too).
Speed is generally pretty good, and I cannot notice if 1 or 10 people
are using it. I set most layers as read-only using a select-only role,
while managers can add and edit layers if they login. In addition, we
have ArcGIS and AutoCAD Map 3D users which can also use the same spatial
database (with extra software and database setup, mind you).
QGIS has a SPIT plugin for easy uploading of shapefiles to a PostGIS
server. The only investment is figuring out PostGIS and PostgreSQL. I
have found the time learning this side of spatial data management well
invested, but certainly a steep learning curve. There are a few
tutorials available on the web to get you started, such as:
http://www.foss4g2007.org/workshops/W-04/ (see Materials at bottom).
-Mike
Ibanez François wrote:
> Hello,
> I'm about to choose QGIS as GIS viewer for my administration (I have shape and Mapinfo files), but there is a big problem.
> All the data are on a server, and when I'm alone to load data on my computer, all is perfect.
> The problem is when there is more than one user loading data on the same server !? All is very slow suddenly... The only solution is just one user stay connected, and have to reload Qgis again.
> Do you know if there's something special to do to avoid sharing problem ?
> The main interest is to load data from the same database between a lot of users, no ??
> Thanks a lot.
> Fran
> Qgis-user mailing list
