[Qgis-user] importing GPX files
chris h
chris123 at magma.ca
Wed Oct 1 18:47:12 PDT 2008
Greets:
Seem to have a snag on Quantum GIS - 0.11.0-Metis 'Metis' (unknown) running on
linux. Here are the symptoms.
1. Load wms blue marble from lizard tech
2. Zoom in to the area of interest
3. Load .gpx file as a new layer
All good so far then save as image, close file and do not save the project.
All good so far.
Now the problem starts. Next day load same WMS bllue marble file and repeat
import of new gpx layer, and a nag screen pops up and says the gpx file has
already been loaded should it be loaded again. Click yes and it aborts. Not
good.
So remove via apt-remove, go in and clean up all the system files, config
files and cache file from the previous session not removed by apt, reboot to
clear out the memory and reinstall qgis. This all works fine
Try to repeat scenario as above (1),(2),(3) and the same error appears no
matter what I call the file. It just does not want to import any .gpx file.
Any clues?
/ch
