[Qgis-user] WMS and Proxy
Stephan Holl
stephan.holl at intevation.de
Wed Oct 15 00:03:57 PDT 2008
Hello Andreas,
Andreas Neumann <a.neumann at carto.net>, [20081014-22:19:33]:
> I added two WMS/postgis related bug reports:
> https://trac.osgeo.org/qgis/ticket/1350
> and
> https://trac.osgeo.org/qgis/ticket/1351
> Thank you for commenting/having a look at these bug reports.
> Andreas
> Carson Farmer wrote:
> > Bump
> >>> Hello QGIS Developers,
> >>> I have problems using external WMS across the proxy.
> >>> I set the correct proxy data at "Settings" --> "Options" -->
> >>> "Proxy"-tab.
> >>> When the proxy is inactive I can access my local WMS services,
> >>> but no external ones (this is like expected). When the proxy is
> >>> active I can neither access my local WMS services nor external
> >>> ones. I'd expect at least being able to access the external
> >>> services when the proxy is active.
> >>> I'd like being able to enable/disable proxy per WMS/Postgis
> >>> connection because I want to use a combination of internal and
> >>> external WMS services.
> >>> In the WMS and DB connection dialogues there should be a checkbox
> >>> "Use Proxy".
> >>> I wonder if other QGIS users have problems with the proxy
> >>> settings as well.
> >>> Thank you for feedback/information on the issue.
> >>> Andreas
> >>> Andreas Neumann
> >>> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
> >>> Email: a.neumann at carto.net, Web:
> >>> * http://www.carto.net/ (Carto and SVG resources)
> >>> * http://www.carto.net/neumann/ (personal page)
> >>> * http://www.svgopen.org/ (SVG Open Conference)
> >>> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> We're also having problems with proxy:
> >> Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
We have this problem as well. It seems that QT does something wrong
here. I tried with qt4.1 and everything works as expected, QT 4.4 shows
your error.
I think that QT does a CONNECT request, which is not understood by the
proxy?! But I leave that for the more knowledgeable.
Just a guess.
Best regards
Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20081015/53d2e5c1/attachment.sig>
