[Qgis-user] WMS and Proxy
Andreas Neumann a.neumann at carto.net
Tue Oct 14 13:19:33 PDT 2008
I added two WMS/postgis related bug reports:
https://trac.osgeo.org/qgis/ticket/1350
and
https://trac.osgeo.org/qgis/ticket/1351
Thank you for commenting/having a look at these bug reports.
Andreas
Carson Farmer wrote:
> Bump
>>> Hello QGIS Developers,
>>> I have problems using external WMS across the proxy.
>>> I set the correct proxy data at "Settings" --> "Options" -->
>>> "Proxy"-tab.
>>> When the proxy is inactive I can access my local WMS services, but no
>>> external ones (this is like expected). When the proxy is active I can
>>> neither access my local WMS services nor external ones. I'd expect at
>>> least being able to access the external services when the proxy is
>>> active.
>>> I'd like being able to enable/disable proxy per WMS/Postgis connection
>>> because I want to use a combination of internal and external WMS
>>> services.
>>> In the WMS and DB connection dialogues there should be a checkbox "Use
>>> Proxy".
>>> I wonder if other QGIS users have problems with the proxy settings as
>>> well.
>>> Thank you for feedback/information on the issue.
>>> Andreas
>>> Andreas Neumann
>>> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
>>> Email: a.neumann at carto.net, Web:
>>> * http://www.carto.net/ (Carto and SVG resources)
>>> * http://www.carto.net/neumann/ (personal page)
>>> * http://www.svgopen.org/ (SVG Open Conference)
>>> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> We're also having problems with proxy:
>> Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
>> Server: squid/2.6.STABLE12
>> Date: Tue, 14 Oct 2008 14:47:56 GMT
>> Content-Type: text/html
>> Content-Length: 1032
>> Expires: Tue, 14 Oct 2008 14:47:56 GMT
>> X-Squid-Error: ERR_ACCESS_DENIED 0
>> X-Cache: MISS from proxy.arpa.piemonte.it
>> Via: 1.0 proxy.arpa.piemonte.it:3128 (squid/2.6.STABLE12)
>> Proxy-Connection: close
>> Whereas Firefox with the same settings works ok.
>> pc
> We are having the same problem:
> server: squid/2.5.STABLE14
> mime-version: 1.0
> date: Tue, 14 Oct 2008 15:35:22 GMT
> content-type: text/html
> content-length: 1045
> expires: Tue, 14 Oct 2008 15:35:22 GMT
> x-squid-error: ERR_ACCESS_DENIED 0
> x-cache: MISS from whitethorn.nuim.ie
> proxy-connection: close
Andreas Neumann
Böschacherstrasse 6
CH-8624 Grüt (Gossau ZH)
Switzerland
Phone: ++41-44-2736668
Web: http://www.carto.net/neumann/
SVG Examples: http://www.carto.net/papers/svg/samples/
SVG.Open: http://www.svgopen.org/
