[Qgis-user] WMS and Proxy
Carson Farmer
carson.farmer at gmail.com
Tue Oct 14 08:37:41 PDT 2008
Bump
>> Hello QGIS Developers,
>> I have problems using external WMS across the proxy.
>> I set the correct proxy data at "Settings" --> "Options" --> "Proxy"-tab.
>> When the proxy is inactive I can access my local WMS services, but no
>> external ones (this is like expected). When the proxy is active I can
>> neither access my local WMS services nor external ones. I'd expect at
>> least being able to access the external services when the proxy is active.
>> I'd like being able to enable/disable proxy per WMS/Postgis connection
>> because I want to use a combination of internal and external WMS services.
>> In the WMS and DB connection dialogues there should be a checkbox "Use
>> Proxy".
>> I wonder if other QGIS users have problems with the proxy settings as
>> well.
>> Thank you for feedback/information on the issue.
>> Andreas
>> Andreas Neumann
>> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
>> Email: a.neumann at carto.net, Web:
>> * http://www.carto.net/ (Carto and SVG resources)
>> * http://www.carto.net/neumann/ (personal page)
>> * http://www.svgopen.org/ (SVG Open Conference)
>> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> We're also having problems with proxy:
> Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
> Server: squid/2.6.STABLE12
> Date: Tue, 14 Oct 2008 14:47:56 GMT
> Content-Type: text/html
> Content-Length: 1032
> Expires: Tue, 14 Oct 2008 14:47:56 GMT
> X-Squid-Error: ERR_ACCESS_DENIED 0
> X-Cache: MISS from proxy.arpa.piemonte.it
> Via: 1.0 proxy.arpa.piemonte.it:3128 (squid/2.6.STABLE12)
> Proxy-Connection: close
> Whereas Firefox with the same settings works ok.
> pc
We are having the same problem:
server: squid/2.5.STABLE14
mime-version: 1.0
date: Tue, 14 Oct 2008 15:35:22 GMT
content-type: text/html
content-length: 1045
expires: Tue, 14 Oct 2008 15:35:22 GMT
x-squid-error: ERR_ACCESS_DENIED 0
x-cache: MISS from whitethorn.nuim.ie
proxy-connection: close
