[Qgis-user] WMS and Proxy
Paolo Cavallini
cavallini at faunalia.it
Tue Oct 14 08:20:15 PDT 2008
> Hello QGIS Developers,
> I have problems using external WMS across the proxy.
> I set the correct proxy data at "Settings" --> "Options" --> "Proxy"-tab.
> When the proxy is inactive I can access my local WMS services, but no
> external ones (this is like expected). When the proxy is active I can
> neither access my local WMS services nor external ones. I'd expect at
> least being able to access the external services when the proxy is active.
> I'd like being able to enable/disable proxy per WMS/Postgis connection
> because I want to use a combination of internal and external WMS services.
> In the WMS and DB connection dialogues there should be a checkbox "Use
> Proxy".
> I wonder if other QGIS users have problems with the proxy settings as
> well.
> Thank you for feedback/information on the issue.
> Andreas
> Andreas Neumann
> Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
> Email: a.neumann at carto.net, Web:
> * http://www.carto.net/ (Carto and SVG resources)
> * http://www.carto.net/neumann/ (personal page)
> * http://www.svgopen.org/ (SVG Open Conference)
> * http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
> Qgis-user mailing list
We're also having problems with proxy:
Warning: UNEXPECTED RESPONSE: [HTTP/1.0 403 Forbidden
Server: squid/2.6.STABLE12
Date: Tue, 14 Oct 2008 14:47:56 GMT
Content-Type: text/html
Content-Length: 1032
Expires: Tue, 14 Oct 2008 14:47:56 GMT
X-Squid-Error: ERR_ACCESS_DENIED 0
X-Cache: MISS from proxy.arpa.piemonte.it
Via: 1.0 proxy.arpa.piemonte.it:3128 (squid/2.6.STABLE12)
Proxy-Connection: close
Whereas Firefox with the same settings works ok.
pc
Paolo Cavallini
http://faunalia.it/pc
