[Qgis-user] recompiling gdal: problems with QGIS?
Agustin Lobo
aloboaleu at gmail.com
Thu Oct 16 02:09:08 PDT 2008
Thanks,
Therefore, I understand I should not try to make the current QGIS I have
work with a new compiled gdal.
BUt could I have a second version of gdal
which I would use for converting ECW and MrSid files to formats that
QGIS can accept?
Agus
Craig Leat wrote:
> Hi Agustin
> Agustin Lobo wrote:
>> Considering that I have QGIS installed from binaries
>> for ubuntu, should I generate another version of gdal or should
>> I remove the gdal that I have first? In the second case,
>> will I be able to tell QGIS where the new gdal is
>> or would I have to compile QGIS as well?
> A general rule is: "DO NOT mix binaries from the repos with self
> compiled components". If you want to self compile then be prepared to
> compile the entire tool chain (gdal, grass, gdal-grass-plugin, qgis).
> I know this rule is not absolute in the sense that I use binaries for
> qt, postgresql, etc, but at least for the core packages it is a rule
> which saves a lot of potential pain. Also be aware that maintaining
> binaries from the repo and a self compiled version at the same time
> (parallel installation of the entire tool chain) is tricky. The
> software may compile against the correct version of a dependency, but
> then may load the incorrect version at run time. Building is straight
> forward *IF* you have a clean system.
> Hope this helps.
> Craig
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
