[Qgis-user] scaling bug?
Andreas Neumann a.neumann at carto.net
Wed Oct 22 01:45:17 PDT 2008
Hi Werner,
QGIS is correct when displaying different map scales when panning the
map in certain projections.
As an example, the default map projection (EPSG 4326) in QGIS, is a
projection where the map scale varies accross the dataset. At 0 latitude
(equator) it has a different map scale compared to Europe or the poles.
For certain projections the scale is only valid in the center of the map
or at the parallels (lines of equal latitude).
Projections can be complex, but if you don't change the default
projection, QGIS is probably right if it displays different map scales
when you pan the map. You probably have to adopt the projection to the
projection most often used in the country you live in.
Andreas
Werner Macho wrote:
> Hi developers and users!
> Maybe I'm just to dumb to understand but probably its also a bug.
> There is a small section called "Scale" in the lower right corner of
> the QGis Main-Window.
> Even when nothing is loaded and I move the map scale is changing. To
> be honest, when I just move a map scaled to a decent scaling I don't
> expect the scaling to change when I just move around.
> Also when I work in the QGIS in windowes mode and i maximize the
> window to "full screen" I personally would expect the scaling to stay
> at eg 1:50000 and not to change.
> The second is just a suggestion but is the first thing a bug or is it
> just me not understanding something?
> Can someone clearify this?
> Thx in advance
> regards
> Werner
> Qgis-user mailing list
