[Qgis-user] move vertex to specified coordinates?
Brent Wood
pcreso at pcreso.com
Wed Oct 22 01:44:13 PDT 2008
Hi Matt,
There are still a few possibilities...
I haven't tried this, but you may be able to type the new vertices into a text file, open the text file as a new layer, snap to that layer, & edit your layer, dragging the appropriate point to the new location, where it should snap to exactly the new coordinates (if snapping works as I expect it to).
You can also edit your layer, zooming in & moving the point, checking the cursor coordinates until they show the desired location.
If you can edit your source data outside of QGIS, for example if it is a PostGIS layer, you could update the point's coordinates
using PostGIS/SQL.
HTH,
Brent Wood
--- On Wed, 10/22/08, Andreas Neumann <a.neumann at carto.net> wrote:
> From: Andreas Neumann <a.neumann at carto.net>
> Subject: Re: [Qgis-user] move vertex to specified coordinates?
> To: "qgis-user" <qgis-user at lists.osgeo.org>
> Date: Wednesday, October 22, 2008, 7:28 PM
> Hi Matt,
> no - this is not possible currently. I agree though, that
> it would be a
> useful addition - maybe along with the general possibility
> to add
> coordinates with numeric values anywhere one can do it
> interactively now.
> Andreas
> Matt Wilkie wrote:
> > Hello,
> > Is it possible to move a vertex by typing in the
> coordinates? e.g. I
> > have a vertex at 59.0,-141.115 but want to it be at
> 59.0,-141.0 ?
> > I'm using qgis v1.0.0-Kore-preview1 on ubuntu
> hardy amd64.
> > thanks,
> Qgis-user mailing list
