[Qgis-user] move vertex to specified coordinates?
Matt Wilkie
maphew at gmail.com
Wed Oct 22 22:44:44 PDT 2008
Aaah, it's working now. Your message prompted me to dig deeper and
discover that there are two different places to specify snapping
tolerances. The first which I described earlier as for setting
click-selection tolerance is under Edit > Options > Digitizing. The
second setting for per-layer feature-to-feature snapping is under File
> Project Properties > Snapping Options.
What is the snapping section under Edit supposed to do?
Thanks!
-matt
On Wed, Oct 22, 2008 at 10:56 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Matt,
> I don't know why it fails for you, but in my projects snapping works
> perfectly fine as expected and similar to all other GIS software. I can
> select one or more snap layers, tolerances and it works fine. I can also
> select whether you want to snap to vertices or segments.
> Maybe you set insufficient snap tolerances? You have to set them in map
> units, as far as I remember.
> Andreas
