[Qgis-user] Edit polygon and measure
Agustin Lobo aloboaleu at gmail.com
Thu Oct 30 14:02:13 PDT 2008
After using the edit tools to
draw candidate footprints for aerial frames,
I have the following suggestions:
1. It would be most useful having the length
of each polygon side displayed while you draw,
as with the measurement tool. And/or, being able to
save as a polygon the figure drawn with the measurement tool.
As I had to draw rectangles of a given size, alternating
both tools was a bit tricky. Another, simpler, solution would
be letting be the measurement figure on the screen while
using the edit tool.
2. New vector layer should take by default the
projection of the project.
3. An option to draw rectangles would be appreciated.
Otherwise, great and simple editing.
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
