[Qgis-user] Re: Manage R
Alessandro Sarretta
alessandro.sarretta at inwind.it
Mon Apr 6 08:39:34 PDT 2009
Carson,
Carson Farmer ha scritto:
> This might have something to do with the fact that rgdal is often
> installed in a separate directory than other R packages (because it
> depends on proj4 and gdal/ogr. When trying to load the library in
> manageR, try specifying the lib.loc or libpath parameter(s), you will
> have to figure out where these packages are installed first, as I do
> not have a Windows machine to check this on. If this doesn't work,
> please let me know, and I'll try to think of something else...
> lib.loc: a character vector describing the location of R library trees
> to search through, or 'NULL'. The default value of 'NULL'
> corresponds to all libraries currently known. Non-existent
> library trees are silently ignored.
> libpath: a character string giving the complete path to the package.
in Windows all packages (included rgdal) are installed in
C:\Programmi\R\R-2.7.0\library\. I tried to set lib.loc and libpath but
without good results. I don't know if I made some errors with paths, but
I tried numerous ones...
Ale
