[Qgis-user] HomeRange plugin updated
John C. Tull
john.tull at wildnevada.org
Wed Apr 8 12:46:26 PDT 2009
I've worked out the OS X linking issues. When I run on a modest
dataset, I now receive the following error. I'd be happy to test with
another shapefile of points if it will help.
An error has occured while executing Python code:
File "/Users/jctull/.qgis//python/plugins/HomeRange_plugin/
HRplugin_dialog.py", line 75, in
QObject.connect(self.buttonBox, SIGNAL("accepted()"), lambda
mth=mth: self.run(mth))
HRplugin_dialog.py", line 170, in run
output = Rcall(geomData, opt)
HRplugin_algorithm.py", line 96, in Rcall
homeranges = rpy.r['HR_cruncher'](data, method=i, prc =
opt["methods"][i]["percent"])
File "/Library/Python/2.5/site-packages/rpy2/rpy_classic.py", line
214, in __call__
res = self.__sexp(*args_r, **kwargs_r)
RRuntimeError: Error in kernelUD(dd[, c("X", "Y")], dd[, "ID"], h =
"LSCV", grid = grid) :
At least 5 relocations are required to fit an home range
Python version:
2.5.1 (r251:54863, Jan 13 2009, 10:26:13)
[GCC 4.0.1 (Apple Inc. build 5465)]
Python path:['/Applications/qgis1.1.0.app/Contents/MacOS/share/qgis/
python', '/Users/jctull/.qgis//python/plugins', '/Applications/
qgis1.1.0.app/Contents/MacOS/share/qgis/python/plugins', '/Library/
Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/
Library/Python/2.5/site-packages/Shapely-1.0.4-py2.5.egg', '/Library/
Python/2.5/site-packages/simplejson-1.9.2-py2.5-macosx-10.5-i386.egg',
'/Library/Python/2.5/site-packages/nose-0.11.0.dev_r560-py2.5.egg', '/
Library/Python/2.5/site-packages/setuptools-0.6c9-py2.5.egg', '/
Library/Python/2.5/site-packages/matplotlib-0.98.6svn-py2.5-
macosx-10.3-i386.egg', '/Library/Python/2.5/site-packages/pymc-2.0rc2-
py2.5-macosx-10.3-i386.egg', '/Library/Python/2.5/site-packages/
pytz-2008i-py2.5.egg', '/Library/Python/2.5/site-packages/py2app-0.3.6-
py2.5.egg', '/Library/Python/2.5/site-packages/pyparsing-1.5.1-
py2.5.egg', '/Library/Python/2.5/site-packages/psycopg2-2.0.8-py2.5-
macosx-10.5-i386.egg', '/Library/Python/2.5/site-packages/
PyOpenGL-3.0.0b8-py2.5.egg', '/Library/Python/2.5/site-packages/
scipy-0.7.0-py2.5-macosx-10.5-i386.egg', '/Library/Python/2.5/site-
packages/pyamg-1.0.0-py2.5-macosx-10.5-i386.egg', '/Library/Python/2.5/
site-packages/numpy-1.2.1-py2.5-macosx-10.5-i386.egg', '/usr/local/lib/
wxPython-unicode-2.8.9.1/lib/python2.5/site-packages', '/usr/local/lib/
wxPython-unicode-2.8.9.1/lib/python2.5/site-packages/wx-2.8-mac-
unicode', '/System/Library/Frameworks/Python.framework/Versions/2.5/
lib/python25.zip', '/System/Library/Frameworks/Python.framework/
Versions/2.5/lib/python2.5', '/System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/System/
Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-
mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
python2.5/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/
Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/
Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/
System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/
lib-dynload', '/Library/Python/2.5/site-packages', '/usr/local/lib/
wxPython-unicode-2.8.9.1/lib/python2.5', '/System/Library/Frameworks/
Python.framework/Versions/2.5/Extras/lib/python/PyObjC', '/Users/
jctull/.qgis/python/plugins/fTools/tools']\
Regards,
John
On Apr 7, 2009, at 11:29 PM, Paolo Cavallini wrote:
> Hi all.
> Thanks to Anne, the HomeRange plugin is now updated. It should show
> off
> automagically the next time you open QGIS.
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090408/67422210/attachment.html>
