[Qgis-user] HomeRange plugin updated
Anne Ghisla a.ghisla at gmail.com
Thu Apr 9 01:31:42 PDT 2009
John C. Tull ha scritto:
> I've worked out the OS X linking issues. When I run on a modest dataset,
> I now receive the following error. I'd be happy to test with another
> shapefile of points if it will help.
> An error has occured while executing Python code:
> Traceback (most recent call last):
[cut]
> RRuntimeError: Error in kernelUD(dd[, c("X", "Y")], dd[, "ID"], h =
> "LSCV", grid = grid) :
>   At least 5 relocations are required to fit an home range
this is a normal R error - to compute homeranges, subsets of points
determined by the attribute in the colum you chose (for esample animal
ID, month, year...) must contain at least 5 points. Even one subset with
<5 points raises this error.
I suggest to group points by another column.
On my side, I will change the code to avoid Python error, and raise a
info window instead.
many thanks and best regards,
Anne
> Qgis-user mailing list
