[Qgis-user] HomeRange plugin updated
John C. Tull
john.tull at wildnevada.org
Thu Apr 9 10:25:12 PDT 2009
Here is an error I get now using a shapefile with a set of points
creating home ranges on field 'ID'. There is only one ID for all the
points, so it should create a single home range estimate for each
method.
An error has occured while executing Python code:
File "/Users/jctull/.qgis//python/plugins/HomeRange_plugin/
HRplugin_dialog.py", line 75, in
QObject.connect(self.buttonBox, SIGNAL("accepted()"), lambda
mth=mth: self.run(mth))
HRplugin_dialog.py", line 170, in run
output = Rcall(geomData, opt)
HRplugin_algorithm.py", line 102, in Rcall
singleshp = robjects.r['exporter'](homeranges, attributes, level
= "%d" % opt["methods"][i]["percent"], export = robjects.r.c(opt["io"]
["mode"]), shapename= opt["io"]["layername"], dir="%s" % opt["io"]
["outputfolder"], owr= opt["io"]["overwrite"])
File "/Library/Python/2.5/site-packages/rpy2/robjects/__init__.py",
line 422, in __call__
res = super(RFunction, self).__call__(*new_args, **new_kwargs)
RRuntimeError: Error in writeOGR(khr.polygons, dir, name, "ESRI
Shapefile") :
GDAL Error 1: Failed to create file .shp file.
Python version:
2.5.1 (r251:54863, Jan 13 2009, 10:26:13)
[GCC 4.0.1 (Apple Inc. build 5465)]
Python path:['/Applications/qgis1.1.0.app/Contents/MacOS/share/qgis/
python', '/Users/jctull/.qgis//python/plugins', '/Applications/
qgis1.1.0.app/Contents/MacOS/share/qgis/python/plugins', '/Library/
Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/
Library/Python/2.5/site-packages/nose-0.11.0.dev_r560-py2.5.egg', '/
Library/Python/2.5/site-packages/setuptools-0.6c9-py2.5.egg', '/
Library/Python/2.5/site-packages/matplotlib-0.98.6svn-py2.5-
macosx-10.3-i386.egg', '/Library/Python/2.5/site-packages/pytz-2008i-
py2.5.egg', '/Library/Python/2.5/site-packages/py2app-0.3.6-
py2.5.egg', '/Library/Python/2.5/site-packages/pyparsing-1.5.1-
py2.5.egg', '/Library/Python/2.5/site-packages/PyOpenGL-3.0.0b8-
py2.5.egg', '/Library/Python/2.5/site-packages/scipy-0.7.0-py2.5-
macosx-10.5-i386.egg', '/Library/Python/2.5/site-packages/pyamg-1.0.0-
py2.5-macosx-10.5-i386.egg', '/Library/Python/2.5/site-packages/
numpy-1.2.1-py2.5-macosx-10.5-i386.egg', '/Library/Python/2.5/site-
packages/simplejson-2.0.9-py2.5-macosx-10.5-i386.egg', '/Library/
Python/2.5/site-packages/Shapely-1.0.11-py2.5.egg', '/Library/Python/
2.5/site-packages/psycopg2-2.0.9-py2.5-macosx-10.5-i386.egg', '/
Library/Python/2.5/site-packages/pymc-2.0-py2.5-macosx-10.3-i386.egg',
'/usr/local/lib/wxPython-unicode-2.8.9.1/lib/python2.5/site-packages',
'/usr/local/lib/wxPython-unicode-2.8.9.1/lib/python2.5/site-packages/
wx-2.8-mac-unicode', '/System/Library/Frameworks/Python.framework/
Versions/2.5/lib/python25.zip', '/System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5', '/System/Library/
Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/
System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/
plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/
lib/python2.5/plat-mac/lib-scriptpackages', '/System/Library/
Frameworks/Python.framework/Versions/2.5/Extras/lib/python', '/System/
Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-
tk', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/usr/
local/lib/wxPython-unicode-2.8.9.1/lib/python2.5', '/System/Library/
Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC', '/
Applications/qgis1.1.0.app/Contents/MacOS/share/qgis/python/plugins/
fTools/tools']
On Apr 9, 2009, at 1:31 AM, Anne Ghisla wrote:
> John C. Tull ha scritto:
>> I've worked out the OS X linking issues. When I run on a modest
>> dataset, I now receive the following error. I'd be happy to test
>> with another shapefile of points if it will help.
> [cut]
>> RRuntimeError: Error in kernelUD(dd[, c("X", "Y")], dd[, "ID"], h =
>> "LSCV", grid = grid) :
>> At least 5 relocations are required to fit an home range
> this is a normal R error - to compute homeranges, subsets of points
> determined by the attribute in the colum you chose (for esample
> animal ID, month, year...) must contain at least 5 points. Even one
> subset with <5 points raises this error.
> I suggest to group points by another column.
> On my side, I will change the code to avoid Python error, and raise
> a info window instead.
> many thanks and best regards,
> Anne
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090409/65cebcb7/attachment.html>
