[Qgis-user] Building QGIS 1.0.0 on RHEL4 x86-64
paulo.estrela at petrobras.com.br paulo.estrela at petrobras.com.br
Thu Apr 16 12:02:36 PDT 2009
Hi Juha,
I built all qgis dependencies including qt4 for rhel4. I got the sources
(version 4.4.2) from www.qtsoftware.com and installed them in
/usr/local/qt4. I cannot change to Fedora because my clients use some
proprietary geological interpretation software. As a test I will try
Fedora...
Thanks,
Paulo José Braga Estrela
PETROBRAS - Tecnologia da Informação e Telecomunicações
Analista de Sistemas Jr.
TIC/TIC-E&P/TICDT-BA
EDIBA - Av. Antônio Carlos Magalhães, 1113, 3º Andar
Juha Tuomala <Juha.Tuomala at iki.fi> gravou em 16/04/2009 15:40:57:
> On Thursday 16 April 2009 20:58:58 paulo.estrela at petrobras.com.br wrote:
> > I'm trying to install QGIS 1.0.0 on a RHEL4 x86-64 box and I'm having
> > problems with make. I did the following:
> RHEL4 comes with Qt-3.x and qgis requires Qt-4.x so it wont work.
> I recommend that for desktop use you try Fedora, there Qgis is just
> one yum install command away, already packaged.
>  rpm -qi qgis
> Name        : qgis                         Relocations: (not
relocatable)
> Version     : 1.0.1                             Vendor: Fedora Project
> Release     : 1.fc10                        Build Date: Thu 19 Feb
> 2009 01:01:40 AM EET
> Install Date: Fri 20 Mar 2009 10:15:08 AM EET      Build Host:
> xenbuilder4.fedora.phx.redhat.com
> Group       : Applications/Engineering      Source RPM: qgis-1.0.
> 1-1.fc10.src.rpm
> Size        : 12565739                         License: GPLv2+
> Signature   : DSA/SHA1, Tue 03 Mar 2009 02:29:34 PM EET, Key ID
> bf226fcc4ebfc273
> Packager    : Fedora Project
> URL         : http://qgis.org/
> Summary     : A user friendly Open Source Geographic Information System
> Br,
> Tuju
> Varo hattupäisiä autoilijoita.
"O emitente desta mensagem é responsável por seu conteúdo e endereçamento. Cabe ao destinatário cuidar quanto ao tratamento adequado. Sem a devida autorização, a divulgação, a reprodução, a distribuição ou qualquer outra ação em desconformidade com as normas internas do Sistema Petrobras são proibidas e passíveis de sanção disciplinar, cível e criminal."
"The sender of this message is responsible for its content and addressing. The receiver shall take proper care of it. Without due authorization, the publication, reproduction, distribution or the performance of  any other action not conforming to Petrobras System internal policies and procedures is forbidden and liable to disciplinary, civil or criminal sanctions."
"El emisor de este mensaje es responsable por su contenido y direccionamiento. Cabe al destinatario darle el tratamiento adecuado. Sin la debida autorización, su divulgación, reproducción, distribución o cualquier otra acción no conforme a las normas internas del Sistema Petrobras están prohibidas y serán pasibles de sanción disciplinaria, civil y penal."
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090416/117831eb/attachment.html>
